Thread: What to do after printing?
11-12-2019, 03:32 AM #1
- Nov 2019
Hi, guys. This question may sound extreme stupid, and I may sound like a complete newbie, and that is because I am, so I'm sorry if my questions are stupid. I only ask questions that I can't find answer for anywhere else.
I'm leaning to use a Creality Ender 3, and I'm wondering what I need to do after each print? Do I need to clean the nozzel? do I need to remove the filament from the extruder and clean the inside?
Help is appreciated! And I hope I didn't post this in the wrong section.
11-12-2019, 05:07 AM #2
throw it away and get a prusa mini ;-)
I pretty much never do anything to my printers after printing.
I clear any filament off the printbed, but that's it.
If using pla and not going to be printing again for a few days - good idea to unload. But other than that - most machines are fine as they are.
That said, ender 3's have a LOT more problems than most other printers. But filament left in overnight, shouldn't be one of them :-)
11-12-2019, 07:42 AM #3
- May 2018
- 566
I got into the habit of removing the spool of filament and placing it in a vacuum bag. These are the bags used to store clothing in which you remove a cap on a valve and use a vacuum cleaner to suck the air out. This keep the filament dry (no air, no moisture) and does not take long. I don't heat the nozzle to unload it, I just cut it off with a inch sticking out of the drive housing. Next time I use it I heat it up and retract the filament. This may not work as well if it is not a direct drive extruder..
Good luck!
