Results 1 to 10 of 15
Thread: Looking for PETG Tip
09-05-2019, 07:10 PM #11
- May 2018
- 566
Ok, Not sure that can be done but if not pm me and I will send you my email address.
I think your machine is a direct drive extruder as is mine, you may want to try to reduce your retraction by about half and slow it down. I don't like to have retraction set a lot faster than print speed. Not sure it matters but has always worked for me.
Here are 2 models to print using your PETG settings.
one is a 2 walled square and once printed, it should be 2mm tall and the walls should be .8mm thick.
The second is a 2 layer square which should have NO gaps between the threads and should be .4mm thick. If there are gaps raise your.. I think it said flow rate? It was set to 102% in your settings..
