Results 1 to 10 of 39
10-10-2019, 04:04 PM #37
- May 2018
- 564
You make the adjustment in the EEPROM using the M206 as explained in the previous post. Once that is saved with M500 it stays that way until you change it.
If you adjust it using the Z offset in S3d you need to do it on every single model and replace your Gcode, which is probably not want you want.
If the PEI is working and your stuff is not falling off, don't mess with success :-)
I guess I need to get some PEI to try..
