Results 1 to 10 of 16
Thread: Ender 3 Pro print problem...
07-28-2019, 12:59 AM #1
- Jul 2019
- 11
When my Ender 3 Pro moves across to change position it it continues to extrude filament causing a line to be printed across the print. This happens with all PLA filament i have and every print. I am using Creality Slicer 1.2.2 Ive added some screen shots of the software settings and also of what i last printed. Any help would be great.
07-28-2019, 01:17 AM #2
- Jul 2019
- 11
Im installing Cura to see if changing slicer software makes a difference..
07-28-2019, 04:33 AM #3
- 885
I was unable to locate a manual online for download for the printer you own. Many slicers have a feature known as z-hop. It lifts the nozzle a small amount as the head transitions over the model. You may find that Cura will have that feature, solving your problem. If you are unhappy with Cura, consider also to download PrusaSlicer, another free program of great value.
07-28-2019, 05:30 AM #4
- Jul 2019
- 11
I did find Zhop in the software. It was set to 0.0 i am unsure on what to set it to. I tried 0.075 and the problem is still there. ill check out Prusa. Here is a screen shot of theCreality Slicer Zhop...Thanks for the help i have been working on this all night.
07-28-2019, 09:14 AM #5
- 885
There's no real disadvantage, as far as I can determine, to increase the z-hop to clear your streaks. Make lifts in 0.200 increments for 0.200 layer height and you should be clear.
07-29-2019, 12:58 AM #6
- Jul 2019
- 11
07-28-2019, 09:33 AM #7
increase the length nd speed of retraction.
You've got a bowden extruder, so the retraction length needs to be fairly long to make any real difference.
07-29-2019, 12:50 AM #8
- Jul 2019
- 11
When you say length and speed of the retraction.... do you mean then minimum travel? Option #1 in the menu?
07-29-2019, 02:11 AM #9
- Jul 2019
- 11
I set the Zhop to 0.200 and the minimum travel to .5. i dont think the streaks are as thick.
07-29-2019, 08:29 AM #10
retraction is set on the layer tab I think (haven't got it installed on this computer).
Minimum travel just makes it retract more over gaps.
I always have it ticked to always retrack during travel.
