Thread: Makerbot Mini Alternate Firmware
07-31-2019, 11:36 AM #1
- Apr 2018
- 6
Hello, I am having two separate issues with my simplify 3d software interacting with my makerbot mini.
I contacted Simplify3D support and they said that it could be due to the default firmware that my Mini has, anyone know of some alternatives that I could use for the firmware? Does something like Sailfish work with a Mini and Simplify3D with the features I am missing?
It works perfectly fine with the lulzbot I am also controlling from the same machine but when I am using the Mini I have some issues. It will print everything perfectly, but after a successful print is completed I need to restart my mini printer to be able to get it to reconnect to my computer. It will show up under the machine control panel as a port option but will be unable to connect. If necessary I can provide screenshots of this.
Second is that I am having a problem where I can't manually set the extruder temperature from the machine control panel. When it is connected I press the Set button but nothing happens even if the target temperature is set correctly on the left of the current temperature. I need to be able to use this feature to be able to safely change out filament from my printer without having to go back to the makerbot print software. I tried to use gcode to fix do this manually but I get an error saying that it cannot open plaintext gcode files due to the firmware
Any tips related to my issues would be invaluable, thanks!
My 3D Norn Emissary print
09-13-2024, 02:28 AM in 3D Printing Gallery
