Results 1 to 8 of 8
06-03-2019, 02:00 PM #1
- Jun 2019
- 6
Change motor direction with Full graphic smart controller
Hello,
i am building my own 3d printer.
As part of calibration process i need to reverse the motor direction to skip gantry back and forth.
I dont know if it is normal that you cant change the direction of your motors with the Full graphic smart controller.
So thats why i ask. Is that possible, did i oversee something in the configuration.h in Marlin?
I cannot calibrate printer if i need to remove the belt everytime gantry has reached end of printer.....
I need help please....
Kind Regards
BlueOrigin11
06-03-2019, 07:48 PM #2
Would need to see your Configuration.h file.
You can post it to a share like Google Drive and post a link.
06-04-2019, 02:44 AM #3
06-04-2019, 06:34 AM #4
Looked at you Configuration.h file See no reason for no movement.
can you do a test on the end-stops using M119 test each end-stop in the normal position then again with manually Pressed End-Stop
http://marlinfw.org/docs/gcode/M119.html
Would you tell me what 3D Printer you have or Clone 3D Printer.
Do you have a Proximity sensor of an End-stop switch on Z-Axis.
What is your filament diameter. Do you have a Hotbed.
All end-stops set to False, Filament set to 3mm, bed temp sensor set to 0,
I would enable this
//#define EEPROM_SETTINGS // Enable for M500 and M501 commands
I always put something in these, to give further information
#define STRING_CONFIG_H_AUTHOR "(Clif R.)"
#define CUSTOM_MACHINE_NAME "HICi3 v1.1RC8"Last edited by Roberts_Clif; 06-04-2019 at 12:17 PM.
06-04-2019, 06:53 AM #5
- Jun 2019
- 6
I use this electronics kit.
I do currently have no end stops installed. I have some optical sensors here.....
i tried it also on x and y axis . Motor moves only in one direction upon scrolling the Knob in the other direction....
I have also a 220V heating mat.... but not installed yet... and a SSR.
06-04-2019, 06:54 AM #6
- Jun 2019
- 6
https://www.amazon.de/Kuman-Upgraded...a-353041049652
Its my own design....
But my problem is the electronics.... Mechanics move flawlessly
06-04-2019, 07:33 AM #7
- Jun 2019
- 6
ok. I figured out what it was.
Endstop was not installed... So sth in software apparently wasnt closed loop anymore....
Thanks a lot. You helped me a lot.
Best regards
BlueOrigin11
06-04-2019, 12:29 PM #8
