Results 1 to 10 of 15
04-28-2019, 10:02 AM #1
weird - what kind of pva did you use ?
The best stuff is the cheapo glue sticks from pound/buck stores.
mind you you're also the only person I know who uses vinyl transfer tape :-)
As you say, we're all different.
04-28-2019, 10:19 AM #2
I purchased the Elmers glue sticks from E-Bay, But no do not blame the glue Sticks.
Stated the Expensive Build Surface I purchased was no good nothing would stick to it. Do not even want to name the Build Surface.
I used the Vinyl Transfer Paper Tape because I have a 4 foot Vinyl decal Cutter, I did not have Blue Tape. I have lots of vinyl and Transfer Paper tape and Vinyl Transfer Tape.
So I used what I had as a test it worked and did not change until I purchased a new bed surface.
Now I do not use the Tape Method unless it is very small and curvy models and the Paper tape works when my Build Surface does not.
It cost about 10 cents per bed surface of Transfer Paper Tape, I could place only what is needed though prefer the full bed covered.Last edited by Roberts_Clif; 04-28-2019 at 10:48 AM.
04-28-2019, 11:46 AM #3
As I stated the Expensive Build Surface I purchased was no good nothing would stick to it.
I used the Vinyl Transfer Paper Tape because I have a 4 foot Vinyl decal Cutter, I did not have Blue Tape. I have lots of vinyl and Transfer Paper Tape.
It cost about 10 cents per bed surface of Transfer Paper Tape, I could place only what is needed though prefer the full bed covered.Last edited by Roberts_Clif; 05-13-2019 at 07:52 AM.
