Results 1 to 10 of 23
Thread: Ender 3 Pro problem
01-29-2019, 08:57 AM #19
It appears that your gear that moves the filament is not aligned, the gear teeth need to bite into the filament.
The gear could either be reversed or pulled out so the filament centers the teeth.
And one set screw should be tightened onto the flat surface of the stepper motor shaft Key.Last edited by Roberts_Clif; 01-29-2019 at 09:16 AM.
