01-22-2019, 12:12 PM #1
- Dec 2016
- 43
Pegasus 12" Lead Screw Upgrade Guide? Does one Exist
I've been considering this for a while but find just to get the information I have pour over multiple forums, I even seen videos of people's mods in the 12" Pegasus with Lead screws but they don't go into details. Is their a guide of some sort that has been developed listing all the parts you need to purchase, print and assembly. etc?
Thanks
01-26-2019, 07:35 AM #2
You're talking lead screws just on the Z-axis, right?
This doesn't answer your quest for a guide, but... IIRC, most Z-axis lead screw upgrades involve replacement of the z-motor mounts. One option might be to just replace the z axis nut traps, using something like this - i3v Lead Screw Nut Plate. Yeah, that's for an i3v and not a Pegasus, but it'll give you the concept. The mechanical change is just replacing the nut traps, replacing the threaded rods with 8mm lead screws, and replacing the couplers used to connect the rods to the motor shafts. Change the firmware for the new steps per mm and allowing a higher movement rate on Z. Done.
I just did this on my i3v using lead screws from zyltech on ebay. They seem to have good reviews. Many chinese sources seem to have issues with being bent or the pitch being slightly off.
