11-18-2020, 03:10 AM #3
- Nov 2020
Yes, you can go with sedersmith or find an path which can help you give out things well.On the off chance that anybody is intrigued, my companion and I built up a Cura post handling content (he did the crucial step). I truly figure this would be lucky to be a firmware highlight, similar to I composed a solicitation for. Yet, in the then, for those utilizing Cura: You pass it a solitary boundary (work dividing worth), and it parses the main layer gcode for min/max X and Y directions, and afterward replaces the M557 line in your beginning gcode. LevelingMeshOptimizer.py.txt Simply eliminate the .txt, and drop it here: C:\Program Files\Ultimaker Cura 4.5.0\plugins\PostProcessingPlugin\scripts\ You should have a static work leveling order in your beginning gcode, as: M557 X0:200 Y0:200 S20This, query has been strucking all over, do you think it works out? Let me know with it.
