Results 1 to 8 of 8
01-02-2019, 11:18 AM #1
- Jan 2019
- 6
Want to add smart display to this board, is it possible?
This is a Brainwave Pro from my Openbeam Kossel Pro. These pins are empty on the board. Do these pins look like a display can be added?
01-08-2019, 06:07 AM #2
I can't see the connector most boards have for the smart screens - is that the underside of the board ?
01-14-2019, 07:05 PM #3
Perhaps instead of Mike, Mathew, and Terence you should spend your monies on a product from MakerBase, a slightly bigger name in the world of 3d printing. Like the MKS gen L for example. It is a cheap mainboard. And natively works with all MKS touchscreens and also MKS external mosfets for off-board heated bed power.
02-16-2019, 12:56 PM #4
- Jan 2019
- 6
That is the underside of the board. There are labeled pins but I didn't recognize anything that would work with an off the shelf display.
02-17-2019, 04:37 AM #5
02-17-2019, 08:40 AM #6
It appears that this was a Kick-Starter project from 2013
Specifications:
Atmel AT90USB1286 microcontroller
4-axis, 4 endstop control
Extra thermistor output
4 x 2.5A TI DRV8825 stepper driver ICs (with hot-plug damage hardened)
1-1/32 microstepping configurable
250W heated-build platform driver
Onboard replaceable fuse
12-45VCD input
02-18-2019, 05:20 AM #7
well the connector top - middle, looks like the right socket for a smart lcd to me.
It's certainly the same type that mine's plugged into.
03-25-2019, 06:44 AM #8
- Mar 2019
U can add it Its Good
