Results 21 to 30 of 41
01-27-2019, 05:41 PM #21
02-02-2019, 04:24 AM #22
- Jan 2019
- 8
Hey madda - i found this to be very helpfull getting some knowledge about the settings.
profile for ender 3:
http://www.emcu.eu/configure-ultimaker-cura-software-for-use-the-creality-3d-printer-model-ender-3/
Turtorial Cura:
https://all3dp.com/1/cura-tutorial-s...licer-cura-3d/Last edited by OwiHH; 02-02-2019 at 04:41 AM.
02-09-2019, 03:09 AM #23
- Dec 2018
- Sweden
- 22
02-09-2019, 03:10 AM #24
- Dec 2018
- Sweden
- 22
02-09-2019, 08:05 AM #25
Have never printed on Glass, though believe it would be similar as any other surface.
They say to use Elmer's glue sticks for best adhesion. Can you post a picture of what your failed model starts looks like.
02-09-2019, 08:22 AM #26
- Dec 2018
- Sweden
- 22
Didn't get very far this time. Also shouldn't it be a solid layer?
looks like the tread won't connect with each other.
02-09-2019, 08:22 AM #27
- Jan 2019
- 8
Alright could you give me a recommendation to make the print stick to the glass bed. It wont stay put!
Use "Brim" layer option for first layer also helps for small parts sticking to the bed.
02-10-2019, 03:04 AM #28
- Dec 2018
- Sweden
- 22
-I put something behind the spring tightening it.
-Then i raised the bed a bit after watching this guys first layer that resembeld mine https://www.youtube.com/watch?v=AaF28dnDgKA (Need to raise it just a bit more) and
tried "Hictop Blue - .20.curaprofile" that i got from you.
-It stuck onto the bed the entire print so it finished. But i could hear the nozzle going through and breaking some of the infill when it crossed.
It's a massive improvement compared to the others. But it's not flat and is rough wrinkles on the side.
The entire boat is very roughly made if that makes sense.
Is it under extrution?
02-10-2019, 06:06 PM #29
What are you using for Nozzle and Bed temperature.
What print speed percent is Cura set to.
What you are telling me is that you may have too low nozzle temp or the popping sound could be moisture in the filament.
02-11-2019, 07:55 AM #30
- Dec 2018
- Sweden
- 22
printing temp 198C
printing temp Initial layer 198C
Initial printing temp 188C
Final printing temp 183C
Default build printing temp 70C
build printing temp 50C
build printing temp Initial layer 50C
Print speed 60mm/s
Initial layer print speed 10mm/s
Overhanging wall speed 100%
The popping sound could be moisture in the filament
