Results 1 to 10 of 41
02-13-2019, 06:44 AM #1
It is OK.
That it did not finish you got good results you may want to search and print a new tower with higher printer temps.
02-13-2019, 12:55 PM #2
- Dec 2018
- Sweden
- 22
Well here it is, looks like 205C and higher gave good results.
02-13-2019, 06:40 PM #3
Excellent!!!
Any other Questions.
02-14-2019, 09:22 AM #4
- Dec 2018
- Sweden
- 22
Well i tried to print a tension fix twise (https://www.thingiverse.com/thing:3066664) but it came out like this.
What am i doing wrong the heat tower went well. Why won't these.
02-16-2019, 09:40 AM #5
- Feb 2019
Wat temp was this printed at? Based on your heat tower, 215-220 seems to be your sweet spot (maybe a tad higher) - at least for that filament. Have you tried a different roll of filament? I print some PLA filament at 215 and some as high as 230 on my Ender 3, depending on brand. The last pic you posted looks like a cold print to me. Is the nozzle hitting the print?
02-16-2019, 01:01 PM #6
02-19-2019, 12:36 PM #7
- Dec 2018
- Sweden
- 22
After i changed my temperature to 225C (Thanks BigDenver for pointing that out).
My prints became like this.
How come different temperatures are needed for different filament, when the temperature for the filament is on the spool?
However THANK YOU SO MUCH Roberts_clif for sticking around and helping me .
