    Student
    Nov 2018
    Minnesota
    Follow jennytrump On Twitter Add jennytrump on Facebook Add jennytrump on Google+
    How long does it take to 3d print a small object?
    Hi there,
    Thank you in advance.
    how long is a piece of string ?
    Depends on printer, size and complexity of object & print settings.
    a lot less time that it takes to fabricate it in any of the other traditional methods.. :-)If nothing else this hobby teaches patients!For instance a 23mm tall D&D figure can take over an hour to print depending on how intricate it is.. speed is all relative.. You can go from 3d model to part sitting on the table a LOT faster than any other means of prototyping.. for instance, sculpt, in clay, make mold, make casting, post process, paint.I modeled a mounting bracket for a NVR in about 45 minutes and it will take about 2 hours to print. It is 8" long and each hold down is 51mm tall
Tags for this Thread
