Results 1 to 10 of 14
04-17-2016, 08:51 AM #1
Qidi Tech 1 Simplify 3D Startup Script
In Simplify 3D when you select the Flashforge Creator Pro profile the default startup script creates a blob of plastic on the right side of the build platform. If you replace the starting scripts with these it will extrude a line of plastic along the front of the build platform to make sure the extruder is properly primed.
This script was buried in the massive Qidi Tech thread, I thought it would be easier to reference if we made it its own thread.
http://3dprintboard.com/showthread.p...ll=1#post83647
Paste this under the Left Extruder startup script
Code:; **** Qidi Tech Left Extruder start.gcode **** M73 P0 ; Enable build progress G162 X Y F3000 ; Home XY maximum G161 Z F1200 ; Home Z minimum G92 Z-5 ; Set Z to -5 G1 Z0 ; Move Z to 0 G161 Z F100 ; Home Z slowly M132 X Y Z A B ; Recall home offsets M135 T1 ; Load left extruder offsets G1 X-100 Y-75 Z30 F9000 ; Move to wait position off table G130 X20 Y20 Z20 A20 B20 ; Lower stepper Vrefs while heating M126 S[fan_speed_pwm] ; Set fan speed M140 S[bed0_temperature] T0 ; Heat buildplate M134 T0 ; Stabilize bed temperature M104 S[extruder1_temperature] T1 ; Heat left extruder M133 T1 ; Stabilize left extruder temperature G130 X80 Y80 Z40 A80 B80 ; Default stepper Vrefs G92 A0 B0 ; Zero extruders M135 T1 ; Load left extruder offsets G1 X-100 Y-65 F9000 ; Move to front left corner of bed G1 Z0.3 F6000 ; Move down to purge G1 X90 Y-65 E24 F2000 ; Extrude a line of filament across the front edge of the bed G1 X100 Y-65 F180 ; Wait for ooze G1 X110 Y-65 F5000 ; Fast wipe G1 Z1 F100 ; Lift G92 A0 B0 ; zero extruders M73 P1 ;@body (notify GPX body has started) ; **** end of start.gcode ****
Paste this under the Right Extruder startup script
Code:; **** Qidi Tech Right Extruder start.gcode **** M73 P0 ; Enable build progress G162 X Y F3000 ; Home XY maximum G161 Z F1200 ; Home Z minimum G92 Z-5 ; Set Z to -5 G1 Z0 ; Move Z to 0 G161 Z F100 ; Home Z slowly M132 X Y Z A B ; Recall home offsets M135 T0 ; Load right extruder offsets G1 X-100 Y-75 Z30 F9000 ; Move to wait position off table G130 X20 Y20 Z20 A20 B20 ; Lower stepper Vrefs while heating M126 S[fan_speed_pwm] ; Set fan speed M140 S[bed0_temperature] T0 ; Heat buildplate M134 T0 ; Stabilize bed temperature M104 S[extruder0_temperature] T0 ; Heat right extruder M133 T0 ; Stabilize extruder temperature G130 X80 Y80 Z40 A80 B80 ; Default stepper Vref G92 A0 B0 ; Zero extruders G1 X100 Y-70 F9000 ; Move to front right corner of bed G1 Z0.3 F6000 ; Move down to purge G1 X-90 Y-70 E24 F2000 ; Extrude a line of filament across the front edge of the bed G1 X-100 Y-70 F180 ; Wait for ooze G1 X-110 Y-70 F5000 ; Fast wipe G1 Z0.5 F100 ; Lift G92 A0 B0 ; Zero extruders M73 P1 ;@body (notify GPX body has started) ; **** end of start.gcode ****
Code:; **** Qidi Tech Both Extruders start.gcode **** M73 P0 ; Enable build progress G162 X Y F3000 ; Home XY maximum G161 Z F1200 ; Home Z minimum G92 Z-5 ; Set Z to -5 G1 Z0 ; Move Z to 0 G161 Z F100 ; Home Z slowly M132 X Y Z A B ; Recall home offsets M135 T0 ; Load right extruder offsets G1 X-100 Y-75 Z30 F9000 ; Move to wait position off table G130 X20 Y20 Z20 A20 B20 ; Lower stepper Vrefs while heating M126 S[fan_speed_pwm] ; Set fan speed M140 S[bed0_temperature] T0 ; Heat buildplate M134 T0 ; Stabilize bed temperature M104 S[extruder0_temperature] T0 ; Heat right extruder M104 S[extruder1_temperature] T1 ; Heat left extruder M133 T0 ; Stabilize right extruder temperature M133 T1 ; Stabilize left extruder temperature G130 X80 Y80 Z40 A80 B80 ; Default stepper Vrefs G92 A0 B0 ; Zero extruders G1 X100 Y-70 F9000 ; Move to front right corner of bed G1 Z0.3 F6000 ; Move down to purge G1 X-90 Y-70 E24 F2000 ; Extrude a line of filament across the front edge of the bed G1 X-100 Y-70 F180 ; Wait for ooze G1 X-110 Y-70 F5000 ; Fast wipe G1 Z0.5 F100 ; Lift G92 A0 B0 ; Zero extruders M135 T1 ; Load left extruder offsets G1 X-100 Y-65 F9000 ; Move to front left corner of bed G1 Z0.3 F6000 ; Move down to purge G1 X90 Y-65 E24 F2000 ; Extrude a line of filament across the front edge of the bed G1 X100 Y-65 F180 ; Wait for ooze G1 X110 Y-65 F5000 ; Fast wipe G1 Z1 F100 ; Lift G92 A0 B0 ; Zero extruders M73 P1 ;@body (notify GPX body has started) ; **** end of start.gcode ****
