Thread: missing half step
11-30-2018, 05:09 PM #1
- Nov 2018
missing half step
Hi there, I hope I am in the right section.
I have rebuilt a old stratasys genisys xs 3d printer and have gotten it to print amazing parts but I found its losing step in the x axis.<br>
If i swap it to the Y axis it works but I found the reason is the steps per mm are to low on the X.<br>
If I increase the steps then it will do a 1/16th step when controlling with the computer or the lcd controller but wont print accurately size then.<br>
Is there a way to control or modify it in the marlin firmware?
define DEFAULT_AXIS_STEPS_PER_UNIT 39.513, 65.546, 272.862, 140.65
I am using a ramps 1.4 board<
You can see on the side of the raygun the rings from missing a step.
Any ideas would be appreciated as this printer is built like a tank and like to get it running perfect.
The dark photo is of the pulley and belt it runs on.Last edited by jamesk; 11-30-2018 at 05:17 PM.
Today, 02:50 AM in Tips, Tricks and Tech Help
