Results 1 to 10 of 19
Thread: WTF is wrong with my printer???
11-26-2018, 02:00 PM #14
Try Installing Cura 15.04.6 - Here
Install one or more of the Cura 15.04.6 profile ini files attached.
1st Layer Print speed 32 ~ 46% No Fan
All Other Layers Print speed 70-86% Fan Speed about 50%
I print PLA at 196C ~ 206C with a bed temperature 40C ~ 56C
Check to be sure that your Ender 3 Printer is defined as your Primary 3D Printer...
If you need adjust the temperatures higher in the Cura Profiles as needed.
Hope this will help. I use the same Profiles for ABS only adjust the Nozzle to 228C and the Bed to 96C.
Hope this We will Help.
Sometimes we need more information in order to teach you what is required for that perfect print!
My Profiles work for me they may not work for you.
Your Start G-Code should look like this
G21 ;metric values
G90 ;absolute positioning
M82 ;set extruder to absolute mode
;M106 S127 ;set Fan half speed
M107 ;start with the fan off
G28 X0 Y0 ;move X/Y to min endstops
G28 Z0 ;move Z to min endstops
G1 Z15.0 F{travel_speed} ;move the platform down 15mm
;Put printing message on LCD screen // The line below should contain your Print Message
M117 My Print...
G28 X0 Y0
G1 E4.0 ;prime extruder
G92 E0 ;reset extruder length
;M420 S1 ; Bed Leveling On //// Comment this line it is for my Auto Bed Leveling "On Feature"
M220 S32.000000
Your End G-Code should look like this
M104 S0 ;extruder heater off
M140 S0 ;heated bed heater off (if you have it)
G91 ;relative mode
G1 Z+0.5 E-2 F{travel_speed} ;raise Z above print
G90 ;absolute mode
G1 X0 Y270 ;move extruder to rear left Model to front.
M84 ;steppers off
G90 ;absolute positioningLast edited by Roberts_Clif; 11-26-2018 at 02:20 PM.
