  1. #1
    Help or Suggestions with Print
    I am running into issue printing the posts on this print. I have tried slowing down the print, speeding up the print, more extrusion, less extrusion etc. I just cannot find the right combination of what is going on here and how to fix this. It is currently sliced in Cura I was going to try S3D to see if that yielded different results but I am open to anything at this point.
  2. #2
    Jun 2017
    Location
    Washington State, USA
    It would help to diagnose the Problem with a little more information.
    What are your Cura slicer Settings?
    What Version of Cura are you using?
    What Filament are you using?
  3. #3
    I have attached a screen shot of my cura settings. The cura version is 3.5.1 and I am using 3D Solutech 1.75mm PLA Filament.cura_Settings.jpg
  4. #4
  5. #5
    Jul 2014
    what printer are you using ?
    To me it looks like the posts are being printed too fast and too hot and without adequate cooling between layers.
    (looks at cura settings)
    20mm/s print speed and 215 filament temp.
    ignore the above, you're actually printing too hot and too slow. lol
    drop your printing temp to 200 and up the print speed to 50mm/s and see what happens. You might get a little stringing - but you should get much better cylinders.
    And yes it would slice much better with simplify3d.
    And what sort of print cooling do you have ?
