Results 1 to 10 of 255
02-04-2019, 10:19 PM #30X-CARRIAGE AND EXTRUDER REPLACEMENT
I've had the same Greg's Wade extruder components on my MakerFarm's wood X-carriage since early 2015, and they were continuing to hold up well. The Greg's Wade components used are my refined versions mentioned in the Smoothieboard and Other Upgrades post. Even though my printing has been somewhat infrequent since then, I think it's significant that I've been able to keep the same printed 9-tooth and 47-tooth gears on the printer all this time. Seems like the small gear in particular was always wearing out and needing replacement before. I offer the following reasons for the gears lasting this long: 1) Correcting what appeared to be motor-to-large gear spacing based on an older gear configuration such as 11/45 instead of 9/47, 2) Reducing the amount of edge chamfer on the gear teeth, which essentially made all the teeth wider, and possibly most significant, 3) Reversing the direction of the herringbone pattern so the smaller gear would "dig into" the larger gear during normal extrusion rather than push away from it in the original herringbone gear design.
All that said, I wanted to do something different. I could see my wood x-carriage had a warp or deflection along the upright edge, so it was begging to be replaced. When I would run some thin-wall extrusion tests, I'd see different wall thicknesses on X vs. Y, perhaps caused by the warped carriage tipping the hot end off-kilter a bit. The x-carriage just had an overall clunky look to it, with the large gear, the large stepper motor, the end of the hobbed bolt sticking out, and my hefty part-cooling blower hanging off to the left of the carriage. Finally, I wanted to take apart the e3dv6 for nozzle replacement and some major inspection/cleaning, but doing that on the Greg's Wade installed on the box-style MakerFarm x-carriage is quite an undertaking.
I've migrated to a custom x-carriage plate that holds a Bondtech BMG extruder and an e3d MT-1701 short-body stepper motor. This certainly leads to a cleaner, neater, and likely substantially lighter solution than what I had before. The e3dv6 remains as the hot end, but I've reverted to using the original e3d snap-on cooler instead of my earlier (unpublished) carriage mounted cooling shroud. I liked the concept of a carriage mounted shroud and wanted to retain it, but accommodating something like it was going to complicate the carriage design. For now, I'll just use the e3d cooler. I have, however, retained my preference for flipping the hot end fan so airflow is pulled through the hot end and exhausted to the front of the printer. I've also retained the use of a 10-degree wedge to angle the exhaust airflow up off the bed a bit, should I decide to once again give ABS or some other filament a shot that is sensitive to drafts across the print surface.
As time permits, I'm still working through adjustments and calibrations, but initial prints suggest I've gotten rid of a lot of the ringing or ghosting that I've seen on my prints since day 1. That's a bonus. On the bad side, I hadn't realized how much I always glanced at the large herringbone gear to see what the printer was doing. There's nothing to see on this new setup, and I can't even hear the stepper motor over the hot end fan noise.
The part-cooling blower I had been using with the Greg's Wade configuration is more powerful than the thinner, more common 5015 style, but I opted to shelve it since I believe it is no longer available. Migrating to a new part cooling scheme is another reason why I wanted to redo my x-carriage configuration. Can you see where I mounted a 5015 blower? Hopefully not, since I printed a cover for it in some special stealth-mode filament that I'm testing.
Seriously though, I put the 5015 blower where I always felt the part cooling fan/blower should be on the i3v - behind the carriage, with the blower mounted so the exhaust duct is below the carriage and facing the heater block & nozzle. Glancing at the above images again, you'll see I've changed the wheel configuration of the carriage around so the single adjustment wheel is on top and the two fixed wheels are on the bottom. The duct from the blower will pass from rear to front in the space between the two lower wheels, with mounting holes on the bottom of the carriage to keep it in place.
I haven't finished design work on the duct. Perhaps in a month or so I'll have another update with a completed duct and results from additional printing experience.
I haven't decided whether I'll publish the new x-carriage. I'm not sure how much interest there is in it, especially since it is specific to the i3v (and possibly Pegasus) v-rails, the Bondtech BMG, a short body stepper motor, and the e3dv6 hot end. Many may not like the idea of the rear-mounted part cooler, or the use of e3d's snap-on hot-end cooler. The carriage also requires the right side to be clear of anything, something I already had achieved by relocating my x-endstop to the left side of the printer and my Z-endstop to one of Cloug42's endstops on the far right end of the x-rails. This new carriage also requires use of a specific x-axis cable mount that I'd also have to release. So, we'll see.
Oh - one more thing. It doesn't stand out in the photo, but there is an additional mounting provision on the left side of the carriage, beside the Bondtech. I haven't bought one, but the carriage is also designed for a BLTouch bed sensor. You never know - one of these days I may end up finally jumping on the auto-leveling bandwagon.
Your new carriage would be a direct bolt on for the Pegasus. NP. I would find it useful.
I love the BLtouch probes. I have them on all 3 printers. No more dinking around with adjustments. I think you will like it. I have a hell of a lot fewer issues with prints not sticking these days. The printers are pretty much no touch now.
Quick Navigation
MakerFarm Forum
Top
- Site Areas
- Settings
- Private Messages
- Subscriptions
- Who's Online
- Search Forums
- Forums Home
- Forums
- 3D Printing
- 3D Design / 3D Scanning / 3D Modeling
- Specific 3D Printing Applications / Fields / Conferences
- Specific 3D Printers, Scanners, & Hardware
- RepRap Format Printer Forum
- FlashForge Forum
- Peachy Printer Forum
- MakerBot Forum
- New Matter's MOD-t Forum
- QiDi 3D Printer Forum
- Hyrel 3D Printer Forum
- CTC 3D Printers
- Pegasus Touch Laser SLA Printer Forum
- Einscan-S 3D scanner
- Other 3D Printers / Scanners / Hardware
- FABtotum Forum
- O13Bot
- RapidBot Forum
- Mark One Forum
- Kudo3D Titan 1
- German RepRap
- Solidoodle Forum
- QU-BD One Up & Two Up Forum
- Type A Machines Forum
- Robocular 3D Scanner Forum
- M3D Forum
- Strooder
- UP 3D Printers Forum
- Printrbot Forum
- Ester - Open Source SLS
- DWS DigitalWax Systems
- MBot 3D Printers Forum
- Boots Industries BI V2.0
- The Copperhead Forum
- Be3D Forum
- Sintratec SLS 3D Printer
- 3DMonstr Forum
- Blokify Forum
- LIX 3D Printing Pen
- Fusion3 3D Printers
- 3DPrintBoardPro
- Other
Previous Thread
Next Thread
