Results 1 to 10 of 255
11-07-2014, 08:22 AM #1
My current status:
On a Lets try it and see note, I moved the z end stop to the side of the extrusion, and then tilted it forward to make sure that the endstop switch would hit the frame of the x idler, which it did!!!!! YES!!!!! So I was able to adjust it to get it down maybe 1 or 2 mm, and then attempt to level the bed. I did it fairly quickly and I think it is level. I need to get it down to the paper thickness level, and I agree moving that whole end stop is not accurate. So I will get it adjusted closer.
Do I then attempt to print the test cube, or calibrate the e-steps? So looking forward to actually printing something!!!
