Results 1 to 10 of 17
Thread: Anet A8 - Gaps at circles
08-24-2018, 08:55 PM #1
- Aug 2018
- 8
Hi
since a few weeks or month i have a problem with my Anet A8.
On the printed parts there are gaps at circles, these gaps sometimes go down to the bottom.
At the start of the problem the perimeters of the circles were completely loose.
By now i almost got rid of the gaps but they are still there. But i do not have ideas anymore.
It's mostly the two holes like on the picture. If they are hard to see i will take some more pictures tomorrow.
Maybe some one has an idea how i get rid of them so i can use the printer again.
Anet A8 with .4 mm nozzle, upgraded rods and bearings on the x and y axis (dold mechatronik), many printed upgrades.
Cura 3.4.1 (but the problem stays since a few versions before that)
Red PLA from DasFilament
Heattower printed
Filament measuredLast edited by Jan19998; 08-25-2018 at 09:45 AM.
08-25-2018, 06:55 AM #2
The first two images are the correct size for viewing, However could you please enlarge the last three with the Settings on them.
08-25-2018, 09:46 AM #3
- Aug 2018
- 8
Sorry for that, i have enlarged the setting pictures.
08-26-2018, 10:13 AM #4
- Aug 2018
I cant see any images..
08-26-2018, 11:42 AM #5
- Aug 2018
- 8
Updated them in the first post.
10-01-2018, 12:17 AM #6
- Sep 2018
I have the same exact problem. But anywhere with walls too. All my holes in every model.
I am using a Monoprice Maker Select Plus
I have been battling this for over a month now. Lots of research and experimenting and I just can't figure it out.
The pictures included are printed using Cura's default "draft quality profile" for PLA. One sample has wall thickness of 1.2 and the other is 2.4. So the issue is more obvious in the 2.4 mm wall thickness. So I conclude, the more walls, the more worse the problem. I've played around with the usual settings (temp, speed,..). Things that I have tried so far: Speeds from 15 to 60, Temps from 190 to 205 (surface quality begins to fade beyond 200), optimize wall printing order, skin overlap, changing nozzle + ptfe tube in case of clogs, taking apart hotend and cleaning, cleaning extruder gears, checking resistance from spool holder, using different filaments. The one setting that has made a difference so far is the "Flow Rate". At 110% Flow Rate, this issue disappears. Unfortunately, I've come to realize that this is not a proper fix. At this setting, my tolerances and precision is out of wack. And the top surface is becomes significantly uneven because of all the extra material extruded. I am very desperate for a solution as I have fought this for way too long.
10-01-2018, 05:33 AM #7
try switching off retractions between layers.
Actually making the retractions shorter and faster could help.
I've noticed on these i3 profiles that the retraction settings are really long. 3-6mm. And often done really slowly - like 30mm/s
For my delta (bowden) and my rep clones, direct drive - I only retrace about 2mm and do it as fast as I can - so 60-70mm/s.
It means there are potentially fewer places where the printhead has no filament to deposit.
Think the last setting I had for the ctc i3 prob. were 70mm/s speed and 3mm distance. It's not the best extruder so you do need a decent distance - as long as you do it fast enough it should work. Also for a wall like that - or any single model print, you don't need to retract between layers.
10-01-2018, 08:11 AM #8
- Sep 2018
Thank you for the reply curious aardvark.
Retract at layer change is off by default.
At default it is at 6.5 for retraction. I have tried at 2.0 retraction on most of my profiles at 30 retraction speed. I will bump that up to 70 mm/s and start a test print. Will report back.
10-01-2018, 10:43 PM #9
- Sep 2018
Results are back. Setting retraction speed at 70 mm/s has no effect. Also tested retraction completely off. Same results. My facebook group suggested an e step callibration, which I don't know how to do yet but I'll try. More ideas are welcome.
10-02-2018, 05:19 AM #10
different filament ?
could be caused by inconsistent thickness in the filament I suppose.
You really don't see that very often these days - but it's possible.
