05-13-2014, 12:46 PM #1
MonoPrice Dual Extrusion 3D Printer
Monoprice, a California based discount electronics company, today announced the launch of the MonoPrice Dual Extrusion 3D Printer. The printer will cost just $1199, and feature two extruder heads, meaning that printing with multiple colors is possible. The company claims that this is the cheapest dual extrusion printer on the market. Here are some basic specs for MonoPrice's new machine:
Case Color Black Powder Coated Extruder MK-8 Dual Head with upgraded release Plate Heated Metal Build Plate Print Technology FDM Build Volume 8.9" x 5.7" x 5.9" (225 x 145 x 150 mm) Printing Material ABS/PLA/PVA Filament 1.75mm Layer Resolution ±0.10mm Positioning Precision XY: 11 Microns (0.0004")
Z: 2.5 Microns (0.0001")Layer Thickness 0.1 - 0.5mm Nozzle Diameter 0.40mm Printing Speed 24cc/hour Extruder Temp. 0-250°C Heating Plate Temp. 0-120°C Connectivity USB Cable, SD Card OS Compatibility Windows® XP/Vista®/7/8
Linux, Mac® OS X®Operation LCD Screen + 5 keys control AC Input 100~240 VAC, ~2 amps, 50~60 Hz, 350W Dimensions 18.7" x 12.7" x 15.1" (476 x 322 x 383 mm) Weight 28.7 lbs. (13kg) Software ReplicatorG File Types Input:STL/OBJ
Output:X3G
Further details on this printer can be found here: http://3dprint.com/3678/monoprice-du...ion-3d-printer
Here is a picture of the dual extruders:
05-13-2014, 01:22 PM #2
- Mar 2014
- 157
Hm... looks to be just another Makerbot 2X clone. I like Monoprice though, for their cheap cables / mounts, but this isn't the cheapest dual extrusion printer.
05-15-2014, 05:33 PM #3
- Apr 2014
- 228
No, it is not the cheapest, but this one looks better built than the cheaper ones. Going too cheap in 3D printer world can seriously ruin your weekend or even month, where spending a bit more would have been better.
But it's very hard to tell from limited photos. I'm intrigued, but not sure if I want to be the guinea pig for this one.Last edited by JRDM; 05-15-2014 at 05:35 PM.
05-15-2014, 06:37 PM #4
- Mar 2014
- 157
