Results 1 to 5 of 5
Thread: What went wrong?
07-27-2018, 05:49 PM #1
- Jul 2018
What went wrong?
Hello
I am new in the 3D printer community, and does not know a lot about 3D Printing so far.
I am currently using an Ender 3 3D Printer with PLA filament. I am using the recommended settings on Ultimaker Cura 3.4.1.
I tried to print a one-hand book reading accessory from thingyverse, and it made this weird "offset" in the layers. (Images below)
- I am not quite sure what causes this. I thought it might be bad G-Code but i am not sure.
Hopefully someone in this forum knows what went wrong.
Higher quality images:
https://i.imgur.com/IMfr5vG.png
https://i.imgur.com/nm1FYU0.png
https://i.imgur.com/ijMH985.png
Thanks
07-27-2018, 07:30 PM #2
It appears the the X-Axis belt is loose and slipped, causing the offset.
Difficult to tell with no X,Y-Axis relationship, can you post more pictures showing a larger portion of the bed.
07-28-2018, 04:10 PM #3
- May 2018
- 564
BTW, unless you have tiny fingers, your thumb will not fit in the page holder.. You must scale it up for adult sized thumbs..
08-17-2018, 06:30 PM #4
- Aug 2018
- 6
1st layer didnt stick tight enough
happen all the time
you can buy support ( glue type)
for you 3d bed
and will print out good
08-24-2018, 09:58 AM #5
- Aug 2018
- 18
hope you found out if it was the belt or not
05-13-2024, 03:08 PM in 3D Printer Parts, Filament & Materials
