Results 1 to 10 of 16
Thread: ABS Warping
07-19-2018, 02:34 AM #1
- Feb 2016
- 68
ABS Warping
I have been 3D printing and making a mess for years until I installed Cura from the manufacturers site and now things are much better. My printer is a Cocoon Create and for ABS I put the temperature at 245 degrees and 95 degrees for the bed. So this may be wrong?
There is still two things I need more information on.
1. ABS lifting on the ends. PLA prints good but ABS lifts up at the ends. My printer now lays down a wider brim for the item to sit on and the border sticks good but the print lifts off the wider brim, as per the photo.
2. Is there anything special to do when items span a wide area and it just does not print properly, as in the photo. I will try and print it vertical.
Any comments would be appreciated.
EDIT: I just noticed someone advised this for ABS years ago so I'll try those temperatures. "Change your temp to 230c and 110c for the hotbed".
ABS Lifting.JPGUnsupported Mess.JPGLast edited by Firepower; 07-19-2018 at 03:15 AM.
07-19-2018, 04:53 AM #2
- Jan 2016
- 326
Second photo looks like partly clogged nozzle. Which printer do you have?
07-19-2018, 06:07 AM #3
- Feb 2016
- 68
I have a Cocoon Create which is a copy of something like a Wanhao Duplicator I3. That is printing at 230 degrees but if I go much lower than that it looks like the ABS is not melting properly which is probably right.
In the attached photo the bottom of the centre one inch wide is all rough in both PLA and ABS. Looks like in this one it has to span a smaller space so does not like printing in mid air. A mate mentioned I need to put supports under that area so it prints properly. Not sure if that is right? (Just noticed Cura does supports so am doing a print with supports now.)I am printing it again with Raft on. I'll see how that goes to stop the lifting.
Any other comments would be appreciated.
Just trying different temperatures to stop the supports from having gaps.
FatShark Goggle Supports Broken.JPGLast edited by Firepower; 07-19-2018 at 10:09 AM.
07-19-2018, 02:58 PM #4
- Jan 2016
- 326
ABS requires an enclosed 3D printer with heated bed. Try a different slicer.
07-19-2018, 07:04 PM #5
- Feb 2016
- 68
Mine has a heated bed but is not enclosed. I'll have to work on that.
I did a print last night and got it to stick to the bed for the first time ever in years but it came apart and warped further up this time in various places. Also I still have the Supports not fully formed. I removed the supports on the right of the photo.
Thanks for advising of the General Discussion Thread on ABS Warping. I'll check that out.
07-20-2018, 08:12 AM #6
any particular reason you want to print abs ?
pla and pet-g are both easier to print and just as good ((usually better) for pretty much everything.
You can print abs on an unenclosed printer - if you use a raft. I did that quite successfully for the first 6 months or so of owning a printer. Then I tried pla. No raft, stronger, better, faster, more accurate prints. never touched abs again.
But even with a raft, because of the built in shrinkage, you won't get good layer adhesion with abs.
So abs printed on an open print bed, will always be weaker than pla.Last edited by curious aardvark; 07-20-2018 at 08:17 AM.
07-20-2018, 10:17 AM #7
- May 2018
- 564
Things to check .. you said the print did not stick more than a few times.. Print not sticking would be starting height and the amount of plastic extruded.. if either of these are wrong you are not going to have good luck..
As was said PETG is a better choice for most things you would NEED ABS for like strong parts that will be outside.. It has no smell and no warping..
ABS is good for injection molding and was not invented for FFF.
Go back and make sure the basics are correct, if I have a print that comes loose, it is almost always related to staring height wrong, bed not level or filament diameter inconstancy (way under 1.75mm)
Good luck
07-20-2018, 11:50 AM #8
- Feb 2016
- 68
The reason I have been trying ABS is that I bought 5 rolls when I got the printer almost 3 years ago and always thought that was the best and strongest but will have to try some of the newer ones.
The new Cura seems to be better than the one I installed 2 years ago so for the first time I turned on raft and supports and checked the bed and the print I did last night stuck for the first time in ABS. But as you said the layer adhesion on ABS was bad and many layers came apart.
This is on a very thin long item but a thick item seemed to print perfectly but with little pressure it broke but super glue fixed that.
Thanks for the comments.Last edited by Firepower; 07-20-2018 at 12:12 PM.
07-20-2018, 12:08 PM #9
- Feb 2016
- 68
My PLA sticks to the bed but one long thin item I have not been able to print in ABS without lifting from the bed for years but it worked yesterday when I turned on Raft but the layers separated up higher. Apparently from my printer not being enclosed.
When I bought the printer I bought 6 rolls of PLA which works good and 5 rolls of ABS as they were the main ones a few years back but have not had much success with ABS.
So looks like I need to get some PETG.
Looks like I am understanding things a bit better now so hopefully things will be better.
Thanks.
12-26-2020, 08:35 AM #10
- Feb 2016
- 68
