04-01-2018, 10:33 AM #1
- Sep 2017
PrimaCreator P120 Z Axis not moving
My p120 suddenly stopped working today, the Z axis won't move. Anyone got any ideas what the problem might be? I can hear how the engine tries to move it but nothing happens. This thing does not look fun to disassemble so I hope I won't need too
04-02-2018, 07:37 AM #2
well it looks exactly like a monoprice select mini.
So try searching for results with that rather than a prima creator p120 - which is the first time I've heard of that name for it.
A lot of these machines get rebadged and sold with different names. But what you have there is definitely more commonly known as a mp select mini.
04-02-2018, 08:35 AM #3
- Sep 2017
Okay, thanks! I'll try to find more info then
07-17-2022, 07:19 AM #4
- Jul 2022
A very late answer...but
I do have an answer to your problem. Experienced the same problem last night. If you remove the blue panel in the back of the printer you may see that a bolt without inner threads. If you see this it has loosened from its original place higher up on the threaded axis. I pushed it upwards and managed to put it back in place with a pair of small pliers!Goog luck!
