05-26-2018, 08:19 PM #1
- May 2018
- 9
Error log. posted. What motor is bad?
just as the title says, i have the extruder motor and its clicking alot like it doesn't want to go to its next phase.. with this log is it the board or motor?
1970-01-01 00:05:02,197 - diag_log - INFO - Executing idle current test
1970-01-01 00:05:02,215 - diag_log - DEBUG - Disabling all motors
1970-01-01 00:05:02,324 - diag_log - DEBUG - Measuring standby current
1970-01-01 00:05:02,409 - diag_log - DEBUG - 12v current: 30mA 5v current: 728mA
1970-01-01 00:05:02,462 - diag_log - DEBUG - Validating current measurements
1970-01-01 00:05:02,488 - diag_log - INFO - Checking axis: 0
1970-01-01 00:05:02,731 - diag_log - DEBUG - 12v current: 395mA
1970-01-01 00:05:02,789 - diag_log - DEBUG - Validating 12v current
1970-01-01 00:05:02,923 - diag_log - INFO - Axis: 0 diagnostics finished
1970-01-01 00:05:02,961 - diag_log - INFO - Checking axis: 1
1970-01-01 00:05:03,186 - diag_log - DEBUG - 12v current: 405mA
1970-01-01 00:05:03,263 - diag_log - DEBUG - Validating 12v current
1970-01-01 00:05:03,449 - diag_log - INFO - Axis: 1 diagnostics finished
1970-01-01 00:05:03,468 - diag_log - INFO - Checking axis: 2
1970-01-01 00:05:03,741 - diag_log - DEBUG - 12v current: 329mA
1970-01-01 00:05:03,825 - diag_log - DEBUG - Validating 12v current
1970-01-01 00:05:04,111 - diag_log - INFO - Axis: 2 diagnostics finished
1970-01-01 00:05:04,131 - diag_log - INFO - Motor diagnostics complete
1970-01-04 15:51:09,886 - diag_log - INFO - Executing idle current test
1970-01-04 15:51:09,907 - diag_log - DEBUG - Disabling all motors
1970-01-04 15:51:10,133 - diag_log - DEBUG - Measuring standby current
1970-01-04 15:51:10,213 - diag_log - DEBUG - 12v current: 792mA 5v current: 680mA
1970-01-04 15:51:10,230 - diag_log - DEBUG - Validating current measurements
1970-01-04 15:51:10,249 - diag_log - WARNING - ERROR: Measured current draw above limit. Measured: 792. Limit: 45mA
1970-01-04 15:51:10,267 - diag_log - INFO - Checking axis: 0
1970-01-04 15:51:10,662 - diag_log - DEBUG - 12v current: 534mA
1970-01-04 15:51:10,775 - diag_log - DEBUG - Validating 12v current
1970-01-04 15:51:10,795 - diag_log - WARNING - ERROR: Measured current draw below limit. Measured: -258mA. Limit: 148mA
1970-01-04 15:51:10,913 - diag_log - INFO - Axis: 0 diagnostics finished
1970-01-04 15:51:10,930 - diag_log - INFO - Checking axis: 1
1970-01-04 15:51:11,173 - diag_log - DEBUG - 12v current: 527mA
1970-01-04 15:51:11,226 - diag_log - DEBUG - Validating 12v current
1970-01-04 15:51:11,245 - diag_log - WARNING - ERROR: Measured current draw below limit. Measured: -265mA. Limit: 148mA
1970-01-04 15:51:11,377 - diag_log - INFO - Axis: 1 diagnostics finished
1970-01-04 15:51:11,400 - diag_log - INFO - Checking axis: 2
1970-01-04 15:51:11,658 - diag_log - DEBUG - 12v current: 485mA
1970-01-04 15:51:11,726 - diag_log - DEBUG - Validating 12v current
1970-01-04 15:51:11,745 - diag_log - WARNING - ERROR: Measured current draw below limit. Measured: -307mA. Limit: 98mA
1970-01-04 15:51:11,879 - diag_log - INFO - Axis: 2 diagnostics finished
1970-01-04 15:51:11,897 - diag_log - INFO - Motor diagnostics complete
1970-01-01 00:44:36,839 - diag_log - INFO - Diagnostics begun.
1970-01-01 00:44:37,063 - diag_log - INFO - Executing idle current test
1970-01-01 00:44:37,082 - diag_log - DEBUG - Disabling all motors
1970-01-01 00:44:38,467 - diag_log - INFO - Idle 12v voltage: 12229.2001953125V, stdev 1.8330302238464355V; Idle 5v voltage 5099.2001953125V, stdev 2.9933257102966309V
1970-01-01 00:44:41,720 - diag_log - INFO - Idle 12v current: 396.10000610351562mA, stdev 6.2681736946105957; Idle 5v current 592.0mA, stdev 2.0mA
1970-01-01 00:44:41,729 - diag_log - DEBUG - Validating current measurements
1970-01-01 00:44:41,739 - diag_log - WARNING - ERROR: Measured current draw above limit. Measured: 396.10000610351562. Limit: 35mA
1970-01-01 00:44:41,748 - diag_log - INFO - Checking axis: 0
1970-01-01 00:44:44,482 - diag_log - WARNING - ERROR: Measured current draw above limit. Measured: 739.5. Limit: 575mA
1970-01-01 00:44:44,491 - diag_log - INFO - axis 0 12v current: 739.5 mA avg, stdev 58.896945953369141: FAILS HIGH LIMIT
1970-01-01 00:44:44,716 - diag_log - INFO - Axis: 0 diagnostics finished
1970-01-01 00:44:44,725 - diag_log - INFO - Checking axis: 1
1970-01-01 00:44:47,441 - diag_log - WARNING - ERROR: Measured current draw above limit. Measured: 619.0999755859375. Limit: 575mA
1970-01-01 00:44:47,460 - diag_log - INFO - axis 1 12v current: 619.0999755859375 mA avg, stdev 3.5341193675994873: FAILS HIGH LIMIT
1970-01-01 00:44:47,643 - diag_log - INFO - Axis: 1 diagnostics finished
1970-01-01 00:44:47,653 - diag_log - INFO - Checking axis: 2
1970-01-01 00:44:50,405 - diag_log - INFO - axis 2 12v current: 556.5 mA avg, stdev 7.3654599189758301
1970-01-01 00:44:50,559 - diag_log - INFO - Axis: 2 diagnostics finished
1970-01-01 00:44:50,568 - diag_log - INFO - Motor diagnostics complete
1970-01-01 03:55:08,651 - diag_log - INFO - Diagnostics begun.
1970-01-01 03:55:08,908 - diag_log - INFO - Executing idle current test
1970-01-01 03:55:08,917 - diag_log - DEBUG - Disabling all motors
1970-01-01 03:55:10,462 - diag_log - INFO - Idle 12v voltage: 12238.7998046875V, stdev 1.833030104637146V; Idle 5v voltage 5092.39990234375V, stdev 1.1999999284744263V
1970-01-01 03:55:13,675 - diag_log - INFO - Idle 12v current: 393.10000610351562mA, stdev 16.4222412109375; Idle 5v current 707.0mA, stdev 12.066482543945312mA
1970-01-01 03:55:13,684 - diag_log - DEBUG - Validating current measurements
1970-01-01 03:55:13,693 - diag_log - WARNING - ERROR: Measured current draw above limit. Measured: 393.10000610351562. Limit: 35mA
1970-01-01 03:55:13,703 - diag_log - INFO - Checking axis: 0
1970-01-01 03:55:16,550 - diag_log - WARNING - ERROR: Measured current draw above limit. Measured: 758.70001220703125. Limit: 575mA
1970-01-01 03:55:16,560 - diag_log - INFO - axis 0 12v current: 758.70001220703125 mA avg, stdev 13.37198543548584: FAILS HIGH LIMIT
1970-01-01 03:55:16,788 - diag_log - INFO - Axis: 0 diagnostics finished
1970-01-01 03:55:16,796 - diag_log - INFO - Checking axis: 1
1970-01-01 03:55:19,823 - diag_log - WARNING - ERROR: Measured current draw above limit. Measured: 761.79998779296875. Limit: 575mA
1970-01-01 03:55:19,834 - diag_log - INFO - axis 1 12v current: 761.79998779296875 mA avg, stdev 16.160446166992188: FAILS HIGH LIMIT
1970-01-01 03:55:19,979 - diag_log - INFO - Axis: 1 diagnostics finished
1970-01-01 03:55:19,997 - diag_log - INFO - Checking axis: 2
1970-01-01 03:55:22,804 - diag_log - WARNING - ERROR: Measured current draw above limit. Measured: 693.70001220703125. Limit: 575mA
1970-01-01 03:55:22,813 - diag_log - INFO - axis 2 12v current: 693.70001220703125 mA avg, stdev 12.239688873291016: FAILS HIGH LIMIT
1970-01-01 03:55:22,990 - diag_log - INFO - Axis: 2 diagnostics finished
1970-01-01 03:55:23,002 - diag_log - INFO - Motor diagnostics complete
05-27-2018, 12:12 AM #2
- May 2018
- 9
just tried a good working motor... on the extruder head.. still the same thing
05-30-2018, 02:49 PM #3
- May 2018
- 9
Ok just did trouble shooting.. psu is good, camera is good, all 4 motors as well as the carrieage motor is good.. however i need to find a main board and a carriage board to isolate this problem. this looks like a circuit failure with some of the power drivers to the main board but im not sure yet. even tried 2 new extruders.
