05-07-2014, 01:39 PM #1
Complex Structural Connection Design
I was approached by a local structural engineering firm to make a model. They wanted to have a model of a complex re-bar connection that they could show to a contractor on a project. The model they provided was very complex, with a lot of very thin structural members and fairly complex internal geometry. There was absolutely no way that this could be done with traditional ABS supports; it was just too delicate and complicated to be able to manually remove the support material. Using dissolvable HIPS filament for the supports, I was able to come up with a workable solution - although it took nine tries to come up with a print configuration that produced the desired results.
-Crawford
05-08-2014, 02:13 PM #2
- 67
This looks great. May I ask you what the measurements are on this?
05-13-2014, 01:10 PM #3
They are approximately 6" x 6"; I was limited by the build volume of the Rep 2X. If I were going to do it over again, I'd probably design it as 2 pieces, print them separately, and glue them together. Some of the smaller stirrup pieces didn't print right or broke just because they were so small.
-Crawford
05-14-2014, 04:53 AM #4
- May 2014
- 10
wow, what were they using it for? antitank walls??
05-14-2014, 07:45 AM #5
- Dec 2013
- Georgia
- 934
05-23-2014, 12:26 PM #6
Not entirely sure. This is a column-to-beam connection. My guess is that that need a super-strong rebar connection for a long-span beam. Some of the crazier cantilevered creations by architect Santiago Calatrava are almost all rebar with just a little bit of concrete covering the whole thing!
