Results 11 to 20 of 39
Thread: Einscan-SE to SP conversion
03-09-2021, 01:19 AM #11
- Sep 2017
Hello everyone,
after a long break I am back with a new gift for all of you.
This is how you convert your Einscan-SE to Einscan-SP with a small software patch:
You need a hex editor to do this. I am using HxD and the Einscan EXScan S v3.0.0.1
1. Download any Hex Editor. (HxD)
2. Search following HEX pattern and replace in file sn3dscan.dll
F6 48 89 75 7F 66 66 66 0F 1F 84 00 00 00 00 00 -> F6 48 89 75 7F E9 8A 89 05 00 90 90 90 90 90 90
A8 B1 FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 -> A8 B1 FF FF 45 0F BE 6C 24 28 41 83 FD 02 75 13 43 C6 84 37 99 39 00 00 02 66 0F 19 04 00 E9 57 76 FA FF 43 C6 84 37 99 39 00 00 03 66 0F 19 04 00 E9 44 76 FA FF
3. Go back to where you can choose the scanner type and click on Einscan-SP.
Share your findings and tests here in the forum. This was only tested by one beta-tester but should work for everyone.
Have Fun!
03-18-2021, 02:04 AM #12
- May 2020
Hi eychei,It works like charm! I do realize it scans faster now, have not yet test if it has better accuracy or resolution.Thanks a lot!!
03-28-2021, 02:07 PM #13
- Mar 2021
Hello. I just upgraded my einscan se to the SP version and it works! Thanks for the tip. In terms of performance, for a scan from the rotary table (8 positions) the scan puts 1 "56 with the Einscan SE interface and 1" 01 with the Einscan SP interface! A nice time saver!
For the quality, it is difficult to distinguish a change given the quality already present and the object with which I tested.
03-28-2021, 02:28 PM #14
- Mar 2021
Capture Einscan SE.JPGHere is the scan with einscan SE interface
03-28-2021, 02:28 PM #15
- Mar 2021
Capture Einscan SP.jpgHere is the scan with einscan SP interface
04-11-2021, 07:39 AM #16
- Apr 2021
Confirmed, this works. Did this last evening in about 5 minutes. Important to note for some:
1)When using the search function of your hex editor, ensure you are searching for Hex values, not text-string.
2)It appears as though this doesnt disable the software from using it as SE so thats nice. It enables it to work as SP.
I didnt complete any scans last night, but when doing partial scans, the time difference was noticeable. Much improved. Next scans I will compare details of the scan. Well done eychei!!!!!
04-21-2021, 10:44 AM #17
- Apr 2021
If you want to print out the targets for the turntable someone has added a pdf and svg of them in thingiverse. This should increase quality https://www.thingiverse.com/thing:3050387/files
05-19-2021, 01:37 AM #18
- Apr 2021
Thanks, very practical reminders!
06-23-2021, 06:29 PM #19
- Jun 2021
- 6
Hello,
Ex Scan 3.1 is out and the patch from eychei no longer works.
The first hex patternalready there but the second one doesn't.
Replacing new sn3dscan.dll by the old one induces an error.
@eychei : can you help for this v3.1 ?
07-05-2021, 01:15 AM #20
- Mar 2021
- 6
Is the work of the patch very important to you?
