Results 1 to 10 of 74
08-15-2017, 06:57 AM #11
- Aug 2017
- 8
Software leveling is exactly the same as manually leveling. The difference is the software moves the print head to 3 points on the build plate. Each time it starts at 10mm above it, and you click '+' to move it down 1mm at a time until you feel resistance to moving the paper, then click '-' to back off 1mm. Next you click '+' to move it down .1mm at a time until you feel resistance, then click '-' to back off .1mm. Finally you click '+' to move down .01mm until you fell resistance, then click '+' one more time. You do this over the 3 points. It's a lot more accurate than manually leveling.
I'm looking to go with a glass build area, any suggestions?
