Results 651 to 660 of 757
08-13-2015, 04:20 PM #651
I would suggest getting Arduino to compile the BeckDac release clean with no errors as a starting point. Make sure you can do that with your board set in Tools/Boards. Then, I would use a difference program to compare the two Configuration.h files, and cross over the important settings.
I would not just copy the old file and replace the new file because you are going to break other stuff that has to be there. Unfortunately, you need to go through line by line and cross over the changes. But a good visual diff program will make that just a 5 or 10 minute nuisance.
08-13-2015, 04:22 PM #652
08-14-2015, 07:04 AM #653
- Aug 2015
- 14
Trying to keep a level-head!
Hey Roxy
Just wondered whether you could shed any light on a problem I'm having with auto levelling on a Lulzbot Taz 5 (Rambo 1.3). It's sooooo close to working!!
I built a small capacitive sensor circuit which I installed and replaced my old, static z endstop with. I then installed and configure the BeckDac firmware as recommend (from page 48ish).
I seem to be getting very accurate, repeatable results with the sensor, however, whenever I print the levelling seems too close towards the front-left (closest X0, Y0) and then, if anything, too high towards front-right. The Z-Axis is moving though, so it's obviously trying to compensate.
I do have a glass print bed, and there were suggestions the sensor might not be reading correctly, so I am no printing on a sheet on aluminium but results remain the same.
Here's the calibration piece I'm trying to print:
My start code is:
G28 ; home all axes
G29 n5 ; auto level bed
If I run 'G28 ; G29 V4 T n5' I get this:
******* FIRST RUN ********
RECEIVED: Eqn coefficients: a: 0.01 b: -0.00 d: 0.89
RECEIVED:
RECEIVED: Bed Height Topography:
RECEIVED: --1.61390 --0.90640 --0.21327 +0.44360 +0.99610
RECEIVED: --1.32577 --0.66765 --0.06640 +0.48798 +0.97235
RECEIVED: --1.07202 --0.44702 +0.06423 +0.53923 +0.94985
RECEIVED: --0.85202 --0.27327 +0.18798 +0.61548 +0.99423
RECEIVED: --0.67702 --0.14577 +0.26923 +0.70360 +1.03673
RECEIVED:
RECEIVED: planeNormal x: -0.01 y: 0.00 z: 1.00
RECEIVED:
RECEIVED:
RECEIVED: Bed Level Correction Matrix:
RECEIVED: 0.999958 0.000000 0.009196
RECEIVED: 0.000020 0.999998 -0.002187
RECEIVED: -0.009196 0.002187 0.999955
RECEIVED: ok
******* SECOND RUN ********
RECEIVED: Eqn coefficients: a: 0.01 b: -0.00 d: 0.88
RECEIVED:
RECEIVED: --1.61460 --0.90898 --0.22023 +0.44415 +1.00790
RECEIVED: --1.33210 --0.67273 --0.06773 +0.48540 +0.97602
RECEIVED: --1.07460 --0.45835 +0.06727 +0.54352 +0.95040
RECEIVED: --0.84960 --0.27273 +0.19102 +0.61477 +1.00227
RECEIVED: --0.67273 --0.14210 +0.27165 +0.70165 +1.03040
RECEIVED:
RECEIVED:
RECEIVED:
RECEIVED: 0.999958 0.000000 0.009216
RECEIVED: 0.000020 0.999998 -0.002196
RECEIVED: -0.009216 0.002196 0.999955
RECEIVED: ok
******* THIRD RUN ********
RECEIVED:
RECEIVED: --1.62077 --0.91577 --0.21203 +0.44672 +1.01423
RECEIVED: --1.33452 --0.67515 --0.06953 +0.48735 +0.97860
RECEIVED: --1.07515 --0.45390 +0.05860 +0.53860 +0.94423
RECEIVED: --0.85015 --0.27015 +0.18672 +0.60422 +1.00860
RECEIVED: --0.66453 --0.13703 +0.26860 +0.70047 +1.04172
RECEIVED:
RECEIVED:
RECEIVED:
RECEIVED: 0.999957 0.000000 0.009226
RECEIVED: 0.000020 0.999998 -0.002206
RECEIVED: -0.009226 0.002206 0.999955
RECEIVED: ok
I have the bed purposely quite uneven as I was struggling to tell if the Z-Axis was moving at all to begin with.
I've attached a couple of config files in case they help at all.
Final thought on probe offsets, I believe these are correct. Probe is directly in front of extruder on X axis (0), is 30mm in front of extruder in Y axis (-30), and the gap between the extruder and bed is 2mm which Z is homed (-2).
Any thoughts or recommendations gratefully received! Thanks!!
PS. I've just taken some manual readings from a matching 9 points around the print bed after performing a G28 to home. These are the results which seem to match nicely with what the sensor is saying (+- 0.1).
Y / X | 30 | 147 | 262
285 | -1.7 | -0.2 | +0.8
170 | -1.0 | 0 | +0.9
55 | -0.5 | +0.3 | +0.9Last edited by Astek777; 08-14-2015 at 10:50 AM.
08-14-2015, 11:22 AM #654
That is a lot of difference between the back left and the front right. I would suggest you use the T and V options to level that out as well as you can. You want to get that difference less than .5 mm and preferably, even less than that.
08-14-2015, 01:32 PM #655
- Aug 2015
- 14
Thanks for reply.
So is the routine not able to cope with such large offsets? I only ask as I saw some videos of people printing on really slanty beds (1cm+) just to prove it worked.
As I said in my previous post, it was nearly level originally but I was still getting the same results in the same places as I am now. I was actually getting better results at the time if I just did a G28 and printed without doing a G29 at all, so seems a little odd.
Thanks!
08-14-2015, 02:33 PM #656
Well... There may be more going on than you realize. It depends on your printer, but a lot of times when people are having trouble they can make the problem go away by specifying more points. Usually a 3 x 3 grid is sufficient. But sometimes, it is necessary to go up to a 4 x 4 or even a 5 x 5 grid.
Also... It would be helpful for you to do an M48 command at a few places on the bed and see how repeatable your probe is. If the number is too big, that directly factors into how well the Auto Bed Leveling can compensate. Can you post a few M48 commands for us?
08-14-2015, 03:17 PM #657
- Aug 2015
- 14
Originally I was using 2x2, but generally I've been using 3x3. For the examples above in my original post and further testing I've been doing over the last couple of days I've been using 5 x 5. They all seem to give the same results in the same places.
Here are the results of the M48. I did the 4 corners of my probing square, plus the centre:
M48 x32 y23
RECEIVED: Mean: 2.164063
RECEIVED: Standard Deviation: 0.002223
RECEIVED:
RECEIVED: ok
SENT: M105
SENT: M105
RECEIVED: echo:endstops hit: Z:2.16
M48 x262 y23
RECEIVED: Mean: 3.819562
RECEIVED: Standard Deviation: 0.001582
RECEIVED:
RECEIVED: ok
SENT: M105
SENT: M105
RECEIVED: echo:endstops hit: Z:3.82
M48 x262 y253
RECEIVED: Mean: 3.848125
RECEIVED: Standard Deviation: 0.001452
RECEIVED:
RECEIVED: ok
SENT: M105
SENT: M105
SENT: M105
RECEIVED: echo:endstops hit: Z:3.85
M48 x32 y253
RECEIVED: Mean: 1.183125
RECEIVED: Standard Deviation: 0.001768
RECEIVED:
RECEIVED: ok
SENT: M105
SENT: M105
RECEIVED: echo:endstops hit: Z:1.18
M48 x149 y172 (X/Y Safe Home Position - Centre of Bed)
RECEIVED: Mean: 2.000750
RECEIVED: Standard Deviation: 0.002634
RECEIVED:
RECEIVED: ok
SENT: M105
RECEIVED: echo:endstops hit: Z:2.00
Thanks again for your time looking at this.Last edited by Astek777; 08-14-2015 at 03:50 PM.
08-14-2015, 04:24 PM #658
OK... The repeat-ability seems fine. It is plenty good. I think you should try to level the bed as perfectly as you can and try printing again with a 4 x 4 grid. It that still has issues, please post another G29 T V4 n5 so we can see how the bed looks once it is better leveled.
08-15-2015, 11:40 AM #659
- Mar 2015
- 13
Thanks Roxie for your help. I have the code the same now. I will try to load it up later today and see what it does.
Thanks again. I REALLY do appreciate it. Other forums just don't seem to want to respond.
Bob Keyes
08-15-2015, 01:37 PM #660
- Aug 2015
- 14
Hi Roxy
OK, I've levelled the bed back out so it's now within about 0.3mm across the bed.
I've done two test prints, one using G28 followed by G29 T n5, and one just G28. The print with just G28 seem to print better, although far from perfect. The one with bed levelling was far too close on the front-left (nearest X0,Y0) to the point where it was just blobbing.
PRINT WITH BED LEVELLING
PRINT WITHOUT BED LEVELLING
Here's the 'G29 V4 T n5' response you wanted to see:
RECEIVED: Roxy's Enhanced G29 Auto_Bed_Leveling Code V1.81:
RECEIVED: Full support at http://3dprintboard.com
RECEIVED: Bed x: 32.00 y: 23.00 z: 0.83
RECEIVED: Bed x: 89.00 y: 23.00 z: 0.96
RECEIVED: Bed x: 146.00 y: 23.00 z: 0.99
RECEIVED: Bed x: 203.00 y: 23.00 z: 0.95
RECEIVED: Bed x: 260.00 y: 23.00 z: 0.82
RECEIVED: Bed x: 32.00 y: 80.00 z: 0.82
RECEIVED: Bed x: 89.00 y: 80.00 z: 0.82
RECEIVED: Bed x: 146.00 y: 80.00 z: 0.94
RECEIVED: Bed x: 203.00 y: 80.00 z: 0.89
RECEIVED: Bed x: 260.00 y: 80.00 z: 0.82
RECEIVED: Bed x: 32.00 y: 137.00 z: 0.70
RECEIVED: Bed x: 89.00 y: 137.00 z: 0.70
RECEIVED: Bed x: 146.00 y: 137.00 z: 0.89
RECEIVED: Bed x: 203.00 y: 137.00 z: 0.77
RECEIVED: Bed x: 260.00 y: 137.00 z: 0.80
RECEIVED: Bed x: 32.00 y: 194.00 z: 0.61
RECEIVED: Bed x: 89.00 y: 194.00 z: 0.70
RECEIVED: Bed x: 146.00 y: 194.00 z: 0.80
RECEIVED: Bed x: 203.00 y: 194.00 z: 0.80
RECEIVED: Bed x: 260.00 y: 194.00 z: 0.80
RECEIVED: Bed x: 32.00 y: 251.00 z: 0.38
RECEIVED: Bed x: 89.00 y: 251.00 z: 0.61
RECEIVED: Bed x: 146.00 y: 251.00 z: 0.74
RECEIVED: Bed x: 203.00 y: 251.00 z: 0.80
RECEIVED: Bed x: 260.00 y: 251.00 z: 0.74
RECEIVED: Eqn coefficients: a: 0.00 b: -0.00 d: 0.85
RECEIVED: Mean of sampled points: 0.787550
RECEIVED:
RECEIVED: --0.40880 --0.17317 --0.04692 +0.01433 --0.05067
RECEIVED: --0.17755 --0.08380 +0.01370 +0.01120 +0.00870
RECEIVED: --0.08567 --0.08567 +0.10308 --0.01880 +0.01683
RECEIVED: +0.03620 +0.02808 +0.15558 +0.10245 +0.03308
RECEIVED: +0.04745 +0.16870 +0.19933 +0.16245 +0.02995
RECEIVED:
RECEIVED: planeNormal x: -0.00 y: 0.00 z: 1.00
RECEIVED:
RECEIVED:
RECEIVED: 1.000000 0.000000 0.000586
RECEIVED: 0.000001 0.999999 -0.001098
RECEIVED: -0.000586 0.001098 0.999999
RECEIVED: ok
Again, any help or suggestions greatly received!
Thanks
Sean.
