Results 1 to 10 of 757
09-02-2014, 07:44 AM #11
I don't know if this is the problem.... But there has been a rash of this lately.... If you go into ConfigurationStore.cpp and find the following lines....
SERIAL_ECHO_START;
SERIAL_ECHOLNPGM("Home offset (mm):");
SERIAL_ECHO_START;
SERIAL_ECHOPAIR(" M206 X",add_homeing[0] );
SERIAL_ECHOPAIR(" Y" ,add_homeing[1] );
SERIAL_ECHOPAIR(" Z" ,add_homeing[2] );
SERIAL_ECHOLN("");
SERIAL_ECHO_START;
SERIAL_ECHOPAIR("Z_Probe_Offset (mm): ",zprobe_zoffset); // Added by Roxy to Complete Diagnostic print out
SERIAL_ECHOLN("");
Add the stuff in Bold. Then give your printer an M503 command to see it's values. I'm thinking you have a bad value stored in the EEPROM and it is using that instead of your Configuration.h setting.That will confirm that is why you can't control the Z-Probe offset by making changes to your Configuration.h file. And if so... Then give your printer a M502 followed by a M500 command. That will store an updated value in the EEPROM.
