03-24-2017, 04:44 PM #1
- Sep 2015
itty bitty dual extruder with mismatched hot ends possible?
NOOB question.
Can I use a 1.75mm hexagon and 3.00mm hexagon hotend on the itty bitty dual extruder at the same time? Is there an issue with calibration? Just curious...
thanks
I tried to search the forum but i didnt find any answers or i just dont know how to search the correct terminology..
THanks
again
03-31-2017, 10:25 AM #2
The filament pathway is sized for one or the other filament diameter depending on the extruder body .stl version you printed. so the extruder body can't do 2 different diameters as designed. it might be possible to drill out a 3mm diameter extruder body to 4mm and insert a liner, but it's tricky because the filament path is curved. I think the flex version has a straight filament path so that's a possibility.
The hotends are interchangeable, just need to be set up to the same length and level out the X-Carriage.
