Results 121 to 130 of 354
Thread: 370mm X 250mm X 300mm
09-15-2019, 11:06 PM #121
09-21-2019, 12:01 PM #122
I have finally got the tops of the towers situated and figured out. One thought that I have struggled with is the weight I am adding to the gantry and the fact that i replaced the lower metal frame ends with printed plastic parts. I am or was afraid that the weight of the gantry might crush the plastic and change z height on 1 or both sides. Here is the lower bearing and mount I am talking about..
So I have the metal upper plates flipped upside down so the bearing goes in from the top and I have the collet on top of that so the top of the frame is what is supporting the weight of the gantry. In raw form here is what that looks like..
09-21-2019, 12:05 PM #123
09-21-2019, 09:34 PM #124
09-27-2019, 10:34 PM #125
So I had to do some backtracking. The parts I made to attach the gantry to the linear rails on Z were insufficient and would just slide up and down and off of the metal plates they were supposed to be holding. So I have redesigned these parts. each took just shy of 7 hours to print and the machine uses 4. But that is all behind me now and my machine is really starting to look the part..And from the back..
09-30-2019, 11:35 AM #126
I am gonna get a delta CA. When this is done I am gonna get a Tevo Little Monster and rework it to be a 3 color mixing printer with the diamond hotend. And I will have 2 completely different ways of chasing large color prints. I just gotta get through all this first.
09-30-2019, 06:01 PM #127
So today i have the belts on and adjusted and i have the extruder mounted. From here i plan to move the drag chain from on top of the gantry to underneath the gantry. This is because the Prusa MMU2S unit now sits where the drag chain used to be. And it will look cleaner anyways to bring the wires down and under the gantry..
10-08-2019, 09:29 PM #128
10-08-2019, 09:30 PM #129
10-15-2019, 09:55 PM #130
Since I am now going to be running a 32 bit controller I am going to swap the drivers for X, Y, and E with LV8729 and chase the 1/128 microstepping. I am going to leave Z with the TMC2208 for now.
