01-10-2017, 06:40 PM #1
- Dec 2016
- 43
Drifting issue on X-Axis Assembly
Drifting is the best way to describe it (see Pic) https://drive.google.com/open?id=0B7...tHNEloVV91Z0hB
As you can see the nut is below the trap on the Belt Idler side, this occurs after every print and this results in this side being higher then then the right side (where the Z axis end-stop is located). I have to unscrew it re-seat it and then level the bed after every print. Any idea what could be causing it?. I did note that the Derlin's were tighter then on the other side so I loosened them up. I did contact colin and said it probably the gcode from Simple3D an suggested I just stick with SliC3R 0.99.
