Results 1 to 10 of 68
05-10-2015, 12:17 AM #18
Hello Roxy,
Ive been lurker here and just wanted to say thanks for the huge amount of help you've offered here.
I am just trying to use my z probe for the first time, so I thought I would start out easy by trying the M48, but it doesn't work.
First, I have a delta with a probe that is placed by hand (which means it doesn't need to be engaged or retracted, so just for now, I've inserted a return at the top of those routines) and the switch trigggers when at 18.21mm above the zero location (as determined by the paper test - it prints fairly well at this point.)
When I execute a M48 v3 the probe is lowered to Z_RAISE_BEFORE_HOMING, but then it just stays there, printing out a report with all the same values. Debug statements Ive inserted show the run_z_probe() getting repeatedly called, but nothing moves.
The m119 appears to work fine - the probe (hooked into zmin) is OPEN normally, and TRIGGERED when the switch is closed.
Any ideas?
My 3D Norn Emissary print
09-13-2024, 02:28 AM in 3D Printing Gallery
