Results 1 to 10 of 11
Thread: Conductive filament
04-13-2014, 11:58 AM #1
Conductive filament
Hi all,
So far I have found only one reseller for conductive filament.
http://www.3d2print.net/shop/product...uctive-1-75mm/
Do you know any other ? Have you tried using this kind of product ?
I'm hoping to try it and simplify electrodeposition but if any of you has tried before and is willing to share experience on it, I'd be glad to hear about it.
AM
04-13-2014, 04:17 PM #2
That filament does not conduct electricity. The stated resistance is 10^4 Ohms which is 10K Ohms. It is an insulator.
Old Man EmuLast edited by Compro01; 04-14-2014 at 09:02 AM.
04-13-2014, 07:59 PM #3
Bah beat me to it old man...
Yeah I looked into this stuff before I even got my printer, I wanted to print the wiring on a quadcopter Dual extrusion style... Conductive on one side, ABS on the other and have intergrated wiring all throughout, but after some research discovered it's not really great for that, apparently you can get a LED light to work off it so I've heard.
05-05-2014, 04:11 PM #4
- Dec 2013
- Georgia
- 934
One possibility for printing circuitry is to have the conductive filament traces printed in a hollow channel with openings on the outside of the print and a sprue tree connecting all the exposed ends of the conductive filament. After it's done, do an electroplating process on the whole thing (figuring out a way to deal with bubbles) until the channels are filled with the electroplating metal. Cut the sprues off the part and you have a solid metal trace circuit integrated into the print!
Of course, that's assuming that the conductive filament is conductive enough to take plating a good distance from the point of contact.
05-05-2014, 05:21 PM #5
05-05-2014, 06:06 PM #6
- Dec 2013
- Georgia
- 934
05-06-2014, 02:08 AM #7
- Mar 2014
- 223
05-06-2014, 07:59 AM #8
- Dec 2013
- Georgia
- 934
I can think of situations where running wire without stopping the print multiple times would get very difficult. (Electric motor coils for instance)
How conductive does a plastic have to be in order for it to inherently take electroplating? I've been looking into Polyaniline, which has a resistance of roughly .14 Ohm/cm (varying widely depending on how it's made), but it also has a melting point of 300 deg C and seems to lose it's conductivity slowly in storage after it's made. So not a good material for filament in any case.
05-11-2014, 03:21 PM #9
As a rule of thumb i'd say you need at least 1Amp (as an order of magnitude) to actually do something. So yeah, i feel a bit silly with 10k ohms.
05-15-2014, 02:20 PM #10
- Apr 2014
- 25
I don't know if this is just a stupid question or not, but would that sprayable conductivity solution work for creating 3D printable objects that are conductive?
