  1. #1
    What´s wrong with this print?
    Have been fiddling with the z offset trying to get a near perfect first layer but I don´t know if the z offset is to high or to low.
    I´m using this http://www.thingiverse.com/thing:1734347 as an example print, just printing the first layer with a brim. Don´t know what else I can adjust to get a better print???
  2. #2
    Give us more information regarding your process!
    Just from the picture it could be anything: HBP trammed incorrectly, temps incorrect, speeds incorrect, extruder not calibrated, etc...
  3. #3
    Jul 2014
    looks like over extrusion with parts where the print head is too close to the bed.
    But yeah, some actual details would be useful :-)
  4. #4
    Super Moderator
    Jun 2016
    Location
    Oklahoma
    Also agree - details. What printer, material, temps, speed etc. You probably don't need to mess with the Z offset. A level bed is the most important thing.
  5. #5
    Engineer-in-Training iDig3Dprinting's Avatar
    Jan 2015
    Location
    UK
    Follow iDig3Dprinting On Twitter Add iDig3Dprinting on Facebook Add iDig3Dprinting on Google+ Add iDig3Dprinting on Thingiverse
    The brim looks OK from what we can see.
    Rather than the nozzle being too close it may be the reverse. Is there an issue with the print if you don't mess with the z-offset because it does seem to be a very inconsistent extrusion.
  6. #6
    My printer is an Tronxy i3 (p802ma) with auto leveling bed. I used pla-filament for the print, 200 c extrusion. Didn´t heat the bed since adhesion or warping isn´t an issue with such a small print. Sliced it in Cura and printed it with Repetier-host.
    Might very well be an extrusion problem, any ideas how i could fix that?
  7. #7
    Engineer ralphzoontjens's Avatar
    Nov 2013
    Location
    Tilburg, the Netherlands
    Follow ralphzoontjens On Twitter Add ralphzoontjens on Facebook Add ralphzoontjens on Shapeways Add ralphzoontjens on Thingiverse
    I often print very close to the print bed for the first layer - this looks like your nozzle is too far away so some strands partially detach from the bed.
    See if you can get your nozzle closer and get a paperthin first layer.
