Results 1 to 10 of 11
Thread: Flashforge - Flashprint 3.13
10-08-2016, 08:55 AM #1
Okay I'm sticking this here rather than just in the flashforge section for one reason.
Flashprint has the ability to cut models up and then save the bits as seperate stl files.
This is seriously useful.
If you have a large print and only want to test print a small section of it. this tool lets you chop away the bits you don't want and leave the but you actually want, really quickly and easily.
Once you've got the bit you want, choses 'Save as' and save it as an stl file to import into your usual slicer - assuming you've not got a replicator clone.
If you do have a rep clone of any brand - then choose the creator pro option and export an x3g file.
Looks like direct usb connection is only for the newer flashforge models: dreamer, finder etc.
A fairly basic but adequate settings selection.
Haven't tried a print from it yet - but the ability to chop up models into seperate printable pieces means that I will be using it regularly - if just for that.
Download latest flashprint from here: http://www.flashforge.com.hk/downloads.html
It looks a bit like a modified version of cura - which being opensource, it most likely is.
Shame about the lack of usb support. But what an easy way to chop up models into printable chunks :-)
10-09-2016, 08:10 AM #2
- Oct 2016
Beware of updating to new version 3.13.0!
This morning, upon opening Flashprint (version 3.12.0 64bits), I got an "new update available" window. I downloaded, updated w/ v3.13.0 and OOOPS!
EVERY file I tried to slice ended up in a -very informative - "Something went wrong during slicing" message. This happened not only w/ new stl files, but also w/ previous stls (that v3.12.0 had sliced OK) and even w/ saved fpp ones.
Of course, trying to revert to the previous version by overwriting is not possible (you end up in "a more recent version is already installed" message), so I had to uninstall from control panel and reinstall from scratch.
Fortunately, previously stored user-printing profiles must be saved in some other directory (could'nt find where, if someone knows where these are stored please let me know to back them up, just in case) because they showed up normally (loosing that would have been a real PIA)
Since no release notes are included (just that should have be deterrent enough) I can't judge what I/we could be missing but for me, an occasional buggy slice is better than no slice at all...
Happy printing!
10-18-2016, 07:22 AM #3
- Apr 2016
- Gold Coast, Australia
- 11
I have the release notes from FF in case you're interested. Try disabling the cooling fan at a set height option on your prints (if you have it on). This was a bug I identified that completely stopped slicing from working in FP 3.13.0. I reverted to 3.12 as a result of said bug. Hope that helps?
10-19-2016, 01:17 PM #4
- Oct 2016
Thank you for your response. But no, the cooling fan was off -at least in most models, I only use it for those with fine details-, so it must have been something else.
Anyway, looking at the release notes (that weren't available when I posted, but thanks for offering) I don't see any overwhelming reason for migrating. I'll wait at least for 3.13.1... (a lesson I learned a long, long time ago -I started fumbling w/ PC's in the late 70's, on a Motorola EXORciser; Apple IIs didn't even exist yet- AVOID .0 software releases! )
10-10-2016, 12:46 AM #5
10-10-2016, 05:32 AM #6
install 3.10. First time you run it, it tells you there is an upgrade and downloads 3.13 :-)
Can't find any hidden flashprint directories. But bear in mind that uninstalling a program from the control panel almost never deletes all the files.
Some of the adobe programs can leave gigabytes of data behind.
So most likely it just leaves the profile files alone.
I did slice a couple things with 3.13 and it produced x3g files withouit any issues. That said I use 32bit windows on the grounds that it's faster and considerably less prone to having stuff crash.
I suspect this is another of those instances that proves my point :-)Last edited by curious aardvark; 10-10-2016 at 05:37 AM.
10-18-2016, 08:55 AM #7
- Jun 2016
- Oklahoma
- 904
These types of files would usually be under the C:\USERS directory and whatever sub-directory such as Application Data - ADOBE or Flashprint or even COMMON.
I am going to have to disagree a bit on 32bit Windows being faster! Now, on the same systems with the same amount of memory (max 4Gig) they will be about the same but add any applications that like a lot of memory and 32bit will fall behind fast. Also, 32bit architectures, drivers etc. are becoming scarce.Last edited by wirlybird; 10-18-2016 at 09:14 AM.
10-19-2016, 01:37 PM #8
- Oct 2016
Good tip!
I found my printing profiles in C:\USERS\[PC name]\.FlashPrint\slice_profile
Thanks. A good directory to back up, just in case
BTW, I'm running Win7 64 bits. Otherwise, I'd be out of memory quite often (I do a lot of number crunching, CFD and so on).
curious aardvark: w/ most 32bits OS, you'll be wasting any RAM above 4GB (https://en.wikipedia.org/wiki/Physic...system_support)
10-19-2016, 02:37 PM #9
- Jun 2016
- Oklahoma
- 904
10-10-2016, 07:33 AM #10
FWIW, my OS is 64bit Win8.1. I have had zero problems with 3.13.
