Results 1 to 10 of 12
Thread: Surface resistivity of PLA
09-26-2016, 06:34 AM #1
- Sep 2016
- 15
Does anyone know the surface resistivity of PLA? (Plain PLA with no metals or carbon added.) I have googled it, but I have not found anything relevant.
A typical range or specifications for a particular filament would be useful.
09-26-2016, 09:27 AM #2
it is completely non-conductive. I'd guess that puts the resisitivity at 1
At least when I use my multimeter to see if something is conductice - it sets itself at 1 for zero conductivity. Pla is a solid 1 :-)
I've only just come across the term when researching electroforming.
But basically unmidified pla does not conduct electricity.
Hell the modified stuff does a really lousy job of it.
Is that what you mean ?
09-26-2016, 09:36 AM #3
- Sep 2016
- 15
I have also measured with a multimeter, no contact trough a 0.5mm sample at the 40Mohm scale, but that doesn't mean it's necessarily an insulator. If the surface resistivity is in the 10^9 to 10^12 ohm per square range it will still be static dissipative even if the resistance will be much to high for my multimeter to meassure.
09-26-2016, 09:44 AM #4
what does that mean in english ?
surely something that is 100% non conductive is also an insulator - unless ytou get it wet.
09-26-2016, 10:06 AM #5
- Jun 2014
- Burnley, UK
- 1,662
09-26-2016, 12:17 PM #6
As Mjolinor said, PLA is similar to most plastics in terms of its conductivity/resistivity.
Do you have a particular use in mind? Some of us might be able to comment on whether PLA is suitable.
09-26-2016, 12:20 PM #7
- May 2016
- SE Wisconsin
- 206
Nothing is non-conductive. Static buildup can result in a nasty shock on plastics because the voltage is high enough to allow current flow across the surface and into your fingers.
Which is why when you use PVC pipe to build a dust collection system you need to ground it. it doesn't do much for small shocks but the larger higher voltage ones are reduced. Many people consider that to be a waste of time, but imagine 25,000 volts sparking in a dusty room.
09-26-2016, 01:21 PM #8
09-26-2016, 01:36 PM #9
- Sep 2016
- 15
About 10^13 - 10^16 for PLA.
09-26-2016, 01:42 PM #10
- Sep 2016
- 15
Yesterday, 02:02 PM in Tips, Tricks and Tech Help
