Results 11 to 20 of 25
Thread: Extruding Problem
09-26-2016, 11:05 PM #11
- May 2016
- Annapolis, MD
- 523
It sounds like the filament feed process is getting hung up somehow. The common causes already mentioned include tangled/criss-crossed filament, jammed nozzle due to shmutz or too low a temperature.
I would like to add another one: Misalignment in the filament feed path. Check that the hole in the manifold plate on top of the extruder is actually lined up with the filament feed hole in the top of the extruder carriage release lever.
You might also check that the aforementioned manifold plate is not being pulled down by its forward mounting screw such that it depresses the filament release lever. Stress there can cause the lever to release the filament. I put a spacer on the top of the fan heatsinks to give the manifold plate something to be drawn down against, and shifted the mechanism downward when tightening the two fan / heatsink bolts that hold it in place.
09-26-2016, 11:07 PM #12
- May 2016
- Annapolis, MD
- 523
09-28-2016, 03:14 AM #13
- Sep 2016
- 11
Soooooooooooooo I have narrowed it down to a faulty nozzle. How I don't know as it looks clean as a whistle. I swapped the nozzles over, low and behold swapped the issue over with it.
QIDI's Excellent customer service are sending 2 new nozzles.
The issue i now have if anyone can help. On the left nozzle I have printed 10 things 2 PLA in QIDI FILAMENT and 8 in ABS of 4 USE 3D filament.
Of the 2 PLA 1 failed and 1 had an odd discrepancy part way through
Of the ABS 3 are perfect but since the clicking 5 have stopped part way through. Same settings on heat and bed as the 3 perfect ones
Could it be a filament quality issue or a fan cooling issue. I have a piece that i printed 3 times, twice stopped in same place the third time i upped the temp and it printed a bit more but after where it had stopped previous but consistency was different and then still stoppedLast edited by Kelador; 09-28-2016 at 04:31 AM.
09-28-2016, 04:33 AM #14
- Sep 2016
- 11
09-28-2016, 06:18 AM #15
- Jun 2016
- Oklahoma
- 904
09-28-2016, 06:51 AM #16
- Sep 2016
- 11
09-28-2016, 07:07 AM #17
- Jun 2016
- Oklahoma
- 904
Yea, S3D should zero the fan for ABS.
I wonder if the PTFE tube has a crimp in it that is hindering the movement of the filament? I wonder if it just takes that amount of time for it to back up?
Maybe slow the print speed way down and see if it gets any farther in the print. Just kind of guessing at this point.
09-28-2016, 08:13 AM #18
- Sep 2016
- 11
Cheers for that I have bought some more filament just in case but i hate chucking things away so i will endeavour with what i have till it arrives. So we will see. I will post my results.
Have you ever seen a filament change colour part way through by the way
09-28-2016, 08:53 AM #19
- Jun 2016
- Oklahoma
- 904
09-28-2016, 09:49 AM #20
- Sep 2016
- 11
Fingers crossed my new hatchbox filament works out ok. Seen some good reviews of which im going to go see if i can get a refund on this other one as im sure its that.
