Results 11 to 20 of 42
09-18-2016, 06:13 PM #11
- May 2015
- 107
Actually, I stopped using ReplicatorG and switched to Flashprint and so far, I have not had the issue. I have only done a couple of things so I am not convinced that the issue is solved but things are going in the right direction.
10-06-2016, 11:55 AM #12
- Apr 2015
- Northern Ohio
- 198
10-06-2016, 12:32 PM #13
- Jun 2016
- Oklahoma
- 904
10-06-2016, 12:33 PM #14
- Jun 2016
- Oklahoma
- 904
10-06-2016, 01:12 PM #15
- May 2015
- 107
Thank you for that info wirlybird. I am printing with a temp of 230 and N.F. pretty much oozes out like crazy at that temp.
10-06-2016, 01:26 PM #16
- May 2015
- 107
10-06-2016, 03:13 PM #17
Actually I have to recant my comments about Flashprint. After reading jfkansas's comment I downloaded it and gave it a whirl. Its not bad actually. Calibrations values are a bit different so it took me a while to get materials dialed but now its running very well. Haven't tried a dual extrusion yet as I am busy with a large project. Hopefully I will be able to complete it by Saturday evening and then do some dual stuff on Sunday.
Anyway... Flashprint is in some ways better than Makerware: it has a fresh look to it, all the settings are there that I need to fiddle with, it doesn't do that stupid purge line along the front of the HBP, manual support placement, random layer start points to name a few. I heard (but not tried) that supports and rafts are as junk to remove as with Makerware so that's not good. Ultimately I will invest in S3D.
Makerware 2.4 is the preferred MW release. There are download links in the Flashforge section.
10-08-2016, 07:12 PM #18
- May 2015
- 107
S3D is $150...yikes!!!!
Flashprint....Free!
hmmmm...what to do.
10-08-2016, 07:54 PM #19
- Jun 2016
- Oklahoma
- 904
Can't tell you what to do about S3D but I started with it straight out of the gate and like it. I have tried some of the others a little and found them a pain and the prints weren't as good. I am biased though!
Messed with the new flashprint and it seems ok. Plenty of features.
10-08-2016, 08:05 PM #20
- May 2015
- 107
OK...so what does S3d do that others can't? I mean for $150, there should be a significant improvement in quality of prints I would think. Or at least make coffee.
