Results 31 to 40 of 42
10-10-2016, 06:32 PM #31
- May 2015
- 107
Thanks Todd but the $150 is a lot if S3d doesn't print this any better than the free software. I can email you the file if you want to try it out on S3D.
10-10-2016, 06:45 PM #32
- May 2015
- 107
As you wish Sebastion......
Front looks great!! (2nd pic)
Back...not so much. I did this print with NO supports at all. The printer and ninja-flex actually almost did it.
10-11-2016, 12:37 AM #33
Am I right in assuming that the 'front' was on the build plate and the 'back' was facing up? If so I reckon you may have a calibration issue. If not then try flipping it around so you don't need supports.
Can you upload the file? Or email to sebastian@ecadesign.co.za?
12-09-2016, 07:57 PM #34
- 441
S3D is almost as important as buying the printer itself :P
12-12-2016, 01:05 PM #35
what's supposed to be wrong with that print ? For ninjaflex, it's pretty clean.
12-12-2016, 05:02 PM #36
- May 2015
- 107
You are correct Mr. Aardvark. I was trying to use supports for the overhangs. that is when things went horribly wrong! I discovered that to use supports with ninja-flex, you have to use ninja-flex (using the same extruder) or you get a stringy mess!
01-02-2017, 06:39 PM #37
- Jan 2017
- 9
I am admittedly a newbie on 3D printers but I have a FFCR and I cannot get Flashprint to print even though it appears to talk to the FFCP. I keep getting in a loop when I try to print is pops up a window with parameters and when I continue it asks to save the file. When I do that it goes back to the point where it has the print.
01-02-2017, 07:08 PM #38
- Jun 2016
- Oklahoma
- 904
01-03-2017, 11:25 AM #39
- Jan 2017
- 9
Thanks! As I said, I am a newbie .
01-03-2017, 12:49 PM #40
- Jun 2016
- Oklahoma
- 904
