Results 1 to 10 of 23
08-10-2016, 01:49 AM #1
- Aug 2016
- 21
more tests...
As I mentioned earlier, I started fooling around with some of the settings in the INI. In the Capture Settings.ini, you can change the width of the pattern lines. Here I changed the pixel width in Step 0, from 16pixels to 8 pixels.
[Step0]
pixelWidth=8
frangeNum=100.000000000000
moveNum=12
stepMSecond=40
jumpMSecond=40
[Step1]
pixelWidth=48
frangeNum=94.750000000000
moveNum=5
stepMSecond=40
jumpMSecond=40
Once the ini is saved, the program needs to be restarted for the new settings to take effect. Below are a couple of shots take of the projected image as it looks during a scan.
Unfortunately, there is a big problem with this, the narrower pattern affects the apps ability to mesh accurately (Chek out what happened to the arms). Additionally, the resulting scan doesn't appear that much more detailed, so I think I'll stick with the defaults.
So the improvement I'm getting from the focus adjustment will have to suffice... for now.
