Results 11 to 20 of 23
08-06-2016, 12:06 AM #11
- Aug 2016
- 21
Small world indeed.
To answer your earlier question, the scans are good, don't get me wrong, but I would like to see sharper edges, and better detail on single line grooves and such. The model is 4" tall, and if you look at the photo of the actual figure, you can see how sharp the edges are. The scan has rounded off edges, and the thin grooved lines are no well defined.
08-08-2016, 12:09 AM #12
- Jul 2015
- 29
Taking into account of the correspondence between the projection resolution and camera resolution, in order to avoid the projection of the grid scan data fringe phenomenon, the camera's focus is not together. Also is the manual focus, between the camera focal plane will have a certain deviation, but the depth of field of the camera enough, does not affect to the scan.
08-08-2016, 01:49 AM #13
- Aug 2015
- 241
Getting sharp edges is something even the $100.000,- scanners still have trouble with, that's why there is some very expensive post processing software available to get the scan to it's original sharpness and shape.
you still have to do a lot of manual work.
The only way you can get sharper edges is scanning large size and shrinking to a smaller size.
You could also try Blender, I've seen some tutorials on how to sharpen edges with meshes, but you would need to redraw a lot.
https://www.youtube.com/watch?v=IKABoq5sIEM
08-08-2016, 11:22 AM #14
- Aug 2016
- 21
This past weekend I did a little bit of work on the scanner, and found that I can easily refocus the projector.
So for this purpose, I first used a camera app to set the focus location for the cameras, and had them focus on a medicine bottle with small writing on it. The left camera was in focus at about 14.5", whereas the right camera was in focus at about 15". Both cameras appear to have <1" depth of field.
I then place a white piece of cardboard at 14.75" distance to the projector and projected a test pattern. The front of the projector lens has 2 tiny holes which can be used to adjust the focus, so I was able to adjust it for a (near) perfect focus.
Once adjusted, I ran a calibration test, and did a few scan. My scans a visibly sharper, although still not what I envisioned. Using manual scanning is better and you can see that individual scans are sharper, but the auto aligning process ultimately softens up the final mesh, probably a byproduct of some fudge factor and guesswork needed to align and generate the watertight mesh.
On a side note I found the INI file which governs the projected patterns and I'd like to know more about it, and how to modify the values. can we get an idea of what's what?
08-08-2016, 11:35 AM #15
- Jul 2014
- UK
- 124
08-08-2016, 11:36 AM #16
- Aug 2016
- 21
I've used Meshmixer to great effect to enhance and clean up scans, so I know how to do it, it's just that I was hoping to cut down some of that work.
Actually that doesn't really sharpen anything, all it does is make the edges "appear" sharper because the model (and the triangles) are smaller. If you need sharp edges you need to remesh the area. There's no substitute.
There is a filter in MeshLab that can globally sharpen a mesh by enhancing peaks and valleys, but it invariably makes the surface coarse. There's also an option in MeshMixer that's designed for smoothing, but you can input negative numbers and it becomes a "sharpening" tool, but it too leaves a lot to be desired.
So usually that leaves me with a lot of manual work.
08-08-2016, 11:37 AM #17
- Aug 2015
- 241
it would be nice if adjustments could be made to scan smaller detail objects
maybe you can get more info on the pattern on the David forums ?
08-08-2016, 03:13 PM #18
- Aug 2016
- 21
I've tried that, and I used the Poisson reconstruction filter in Meshlab. Some parts look fine, and in some instances more detailed, but the algorithm used by Einscan is much better at filling in areas with missing data.
So after dedicating almost a whole weekend running various tests and making adjustments, I've pretty much come to the conclusion that the Einscan software is very good at what it does, but it has problems resolving small details, in fact the smaller the scanned object is, the worse the output, but the larger it is, the better the output gets. Probably because it has much more defined (and simply many more) reference points for it's alignment and mesh reconstruction interpolations.
One thing left to explore is the INI file. I don't have it in front of me at the moment, but when I get home tonight, I'll start fooling around with it. From the early look I saw that there are up to 7 steps it can use to project the pattern, but depending on the scan mode or lighting setup, it can use as little as 4 stage. Also there are values describing the pattern (width of each bar, edge blur, etc).
I need to dive into it a bit to see what it does.
I'm not sure the patterns used by the David scanner would be of any use here. David relies on a single camera, and their patterns have both vertical and horizontal lines so the camera can see the deformation in 2 planes. The Einscan uses a pair of cameras producing a stereo image, so it only needs to see the vertical deformation.
08-08-2016, 04:10 PM #19
- Jul 2014
- UK
- 124
Maybe I just got lucky but I've actually been really impressed with the amount of detail it picks out with models as small as 50mm in height.
I've used the David software too and didn't see any higher quality with that although admittedly I only used a cheap webcam.
David is way more configurable and you can use professional grade DSLR cameras with it if you want really high quality.
Personally, I prefer the simplicity and ease of use of the Einscan.
08-10-2016, 01:49 AM #20
- Aug 2016
- 21
more tests...
As I mentioned earlier, I started fooling around with some of the settings in the INI. In the Capture Settings.ini, you can change the width of the pattern lines. Here I changed the pixel width in Step 0, from 16pixels to 8 pixels.
[Step0]
pixelWidth=8
frangeNum=100.000000000000
moveNum=12
stepMSecond=40
jumpMSecond=40
[Step1]
pixelWidth=48
frangeNum=94.750000000000
moveNum=5
stepMSecond=40
jumpMSecond=40
Once the ini is saved, the program needs to be restarted for the new settings to take effect. Below are a couple of shots take of the projected image as it looks during a scan.
Unfortunately, there is a big problem with this, the narrower pattern affects the apps ability to mesh accurately (Chek out what happened to the arms). Additionally, the resulting scan doesn't appear that much more detailed, so I think I'll stick with the defaults.
So the improvement I'm getting from the focus adjustment will have to suffice... for now.
