Results 1 to 10 of 29
08-02-2016, 06:12 AM #1
- Jul 2016
- Pennsylvania, USA
- 255
Hi
The biggest issue you are likely to run into is that the plastics we use in filaments all will "age" quickly in water. The dimensions will change and that likely will impact your part.
Bob
08-03-2016, 09:00 AM #2
what's your evidence for that ?
Commercial parts in cisterns also age - why should 3d printed parts 'age' any quicker ?
It just seems like water will seep through the lines and break down over time.
Pla can be digested but you ned a 'hot' compost heat and the right bacteria to do it. For any purpose that isn't inside a hot compost heap - it's pretty bomb proof.
08-03-2016, 04:46 PM #3
- Jul 2016
- Pennsylvania, USA
- 255
Hi
Most parts that go into plumbing are made from PVC rather than ABS. The parts I printed from ABS that a few years back ... not so nice anymore. Nylon and moisture, same issue on a *lot* of parts. Gears, screws, all sorts of stuff change size over the years. The reason is moisture.
Bob
08-03-2016, 06:11 PM #4
- Jul 2016
- 6
One last thing: for TEMPORARY liquid exposure to liquid solvents/chemicals, is nylon a safe bet? (e.g. the funnel example I mentioned)
According to various charts I've seen- ABS doesn't withstand solvents well at all, not even for a moment. But I don't have direct experience with this yet.
