Results 21 to 30 of 48
08-25-2016, 09:48 AM #21
- Aug 2016
- 22
08-26-2016, 12:55 AM #22
- Jun 2015
- Sydney Australia
- 36
The info I got from BLTouch recommend to position the sensor needle at least 15mm from the nozzle, that does not mean 1.5 inches (38.1mm) will not work, most likely not as effective, also the base of the sensor body needs to be 8.3mm (+/- 0.2mm) above the nozzle tip. I suggest you should make or print a block that is 8.3mm in height to be used to set the sensor height.
My plan is to remove the left extruder (I normally only use the right extruder) this will make space to mount the sensor closer to the right extruder nozzle. I'm planning to design the sensor mount so it's easy to install and uninstall should I ever need to use the left extruder.
08-26-2016, 01:52 AM #23
- Aug 2016
- 22
oh yeah duh i didnt even think to look at that info for the 15mm distance lol.. but yes i know about the 8.3mm abpove nozzle tip and i have already printed the block to use for setting the height i just never did it yet cause i didnt even know if it was a good place to put the sensor or not.. im a rookie at this bare with me please but yeah since i am aa newbie to 3d printing i havent even began to learn about printing with both extruders together so i just been using the left PLA printing and the left for ABS printing so really your plan for removing the 2nd is about the best way to go about it.. i will just follow how you install it.. if that is ok with you of course?? maybe once u get your mount design completed u could possibly share the design. that would be wonderful.. thanks again for all your help
08-26-2016, 02:18 AM #24
- Jun 2015
- Sydney Australia
- 36
My understanding is that the firmware will control the adjustment using the Z-Axis. Before actually starting the print a probing sequence is activated to measure the Z-Axis height on each of the three leveling points, if any of these measurements are outside of the specified height (user defined) the printer will stop and display an error message and will not print, however if the height measurement is within the specified height, the firmware will store these new height measurement in memory and compensate accordingly during the print - this means when you set the layer height at 0.20mm and the sensor probing measures the nozzle height at 0.30mm, and 0.30mm is within the specified height, then the firmware will compensate by lowering the Z Axis 0.10mm during printing. NB. once the probing is completed, the sensor is not used or accessed until you start a new print - the firmware will automatically disable auto-levelling on completion of the print.
As for the BLTouch sensor, it has two sets of wiring, a three wire set which needs to be connected to any servo connection points on FFCP board, and a two wire set which needs to be connected to the Z-MIN connection point because this will allow you to use G_CODE like M131 A to probe point 1, M131 B probe point 2, M132 AB activate auto-leveling, M280 P0 S10 push the sensor pin down. So when you send the G_CODE M280 P0 S10, the firmware sends that code to Z-MIN socket, and because the two wire set of the BLTouch is connected to this socket, the internal program of BLTouch will activate the sensor solenoid to push the sensor pin down.
As mentioned in the first post of this thread you must run Sailfish V7.7 release 4.7, when I checked my FFCP I was running V7.7 release 4.2, so I upgraded my firmware.
Hope this helps
08-26-2016, 02:33 AM #25
Ya, not really. I just don't get the benefit. lol You can't call it auto leveling if it is just measuring is the problem I have with it.
Seems like a lot of work to not really gain any functionality over the z limit switch and a little manual knob turning.
08-26-2016, 05:16 AM #26
- Aug 2016
- 22
08-26-2016, 07:35 AM #27
08-27-2016, 03:15 AM #28
- Jun 2015
- Sydney Australia
- 36
Good news, Flashforge today (27th August) confirm the connection as per the attached image will work.
https://photos.smugmug.com/3D-Printe...ch-FFCP-XL.jpg
Originalt80 you can test by sending the following g-code:
M280 P0 S10 ; sensor pin down
M280 P0 S90 ; sensor pin up
Thank you.
08-27-2016, 04:13 AM #29
- Aug 2016
- 22
gladly but can u suggest what software to use for sending the g-code?
i have the following:
ReplicatorG (included with prointer)
Simplify3D
Printrun-Win-Slic3r-03Feb2015 -- Pronterface
arduino-1.6.9-windows
Flashprint
as stated i am a newbie so if u can point me in the direction where i enter the gcodes to send it would help.. this is all new to me sorry. i will gladly test anyway i can
08-27-2016, 05:35 AM #30
- Jun 2015
- Sydney Australia
- 36
You need to connect your PC via USB connection to FFCP, then:
1. run Simplify3D
2. Click on Tools and select Machine Control Panel
3. Normally Simplify3D will automatically connect to FFCP, if not then click on the Connect button
4. Click on the tab Communication
5. In the dialog box next to the Send button (bottom of the page) type the g-codes
6. Click the Send button
You should see the BLTouch pin head go up and down when you send the g-code
