Results 1 to 10 of 16
07-26-2016, 05:34 PM #1
- Feb 2016
- 15
Filament will not stick right anymore
I have Flashforge Dreamer about 7 mos old. (the one with the clear front access door/panel)
I am using ABS 230degrees @ Nozzle and 110degrees on the plate (after trying different settings) and all worked very well until one day it did not.
It started oozing filament a little more than usual and I removed it just before printing and all cleared up on the test strip except I noticed the test strip was not an even distribution at the start but cleared up at the end.
Next, as the print started, it would not lay down the filament but instead collected as a blob on the nozzle.
Thinking it might be a clogged nozzle, I changed to the Right nozzle which has almost no use and it essentially behaves the same. It makes some sense to change the heat of the plate or nozzle and/or feed rate but because it just started having problems one day, so seems to me something else might be at play. (I am using hatchbox filament and although it has been relocated outside of the machine, the filament is covered when not in use) ( It has been warmer here lately (SoCal) but not enough as compared to other days to think the filament was entering the nozzle that much warmer to make any difference. Humidity is within our normal range)
Anyone have any thoughts?
08-01-2016, 03:38 AM #2
- Jun 2015
- Sydney Australia
- 36
I would do the following:
1) clean the nozzle if the filament is sticking to the nozzle
2) level the bed
3) do a physical measurement of the filament diameter, and compare it to the slicer measurement
Hope this helps
08-01-2016, 09:20 AM #3
08-01-2016, 09:37 AM #4
- Feb 2016
- 15
Thnx Curious...
Is calibrating the same as leveling? if not where can I find the instructions to do so?
08-01-2016, 09:47 AM #5
- Feb 2016
- 15
ejcruz - Thnx (this is my 2nd attest to reply, the first did not "stick" apparently
1) Tried that with acetone and scraping the exterior of both nozzles with not change - Is there are safe way to clean the interior? I have unloaded and reloaded several times w/o it making a difference
2) Did that and the center of the bed seems a little higher that the other 3 check points but the print starts at the outer edge of the plate - Do these plates warp over time? I did a small print at the extreme left/Front and there was less of a problem but it was a different print that those I had been doing
3) Have not done that yet, will do so and report back
08-03-2016, 03:10 AM #6
- Jun 2015
- Sydney Australia
- 36
I let the nozzle cool down then with a small wire brush dipped in acetone (I print with ABS) carefully clean the nozzle avoiding the heater ceramic tape.
When filament starts to accumulate on the nozzle it's an indication:
- exterior of the nozzle needs cleaning
- need to really clean the bed or replace the bed surface such as blue tape etc
- more then likely the nozzle is to far from the bed, hence the suggestion to level the bed
I use Simplify3D so before I actually level the bed, I go to "Edit Process Settings", then click on "G-Code", change the "Origin Offset" Z-Axis to -0.1 to bring the nozzle closer to the bed and do a test print
Hope this helps
08-03-2016, 06:25 AM #7
yes calibrating is the same as levelling.
just used that - brilliant. I usuallly have the machine pretty tightkly calibrated and it leaves a rim on things. So when i don't want a rim - rather than moving the whole bloody printbed - i can just offset the print nozzle by 0.2 or 0.3 mm.
Works a treat.
Far as beds warping goes - yes.
Don't know what they put in the dreamer, but the 3mm aluminium plate they put in the creator lasts about 5 minutes. I put it down to the screws being steel and the plate being aluminium, so when it all heats up the screws expand at a different rate and the plate gradually buckles.
I dropped another 3mm aluminium plate on top of mine, attached with pet tape at corners and never had any more hassle with it.Last edited by curious aardvark; 08-03-2016 at 08:37 AM.
08-04-2016, 02:25 AM #8
Yeah, Bed warp is just something you have to deal with with just about any Flashforge, that's why so many people go for a Glass plate or buy their own plates like Curious and put them on top. My plate is so bad after 5 years it is 1mm higher in the outer edges than it is in the middle.
08-04-2016, 05:45 AM #9
I think it's mainly down to the high temps you need for abs. For whatever reason a lot of us start out with abs, so the beds get a real hammer in the expansion and contraction stakes right from the start.
The knp has a 4 mm aluminium plate and that's stayed flat - but it's never been heated beyond 60, mostly it gets used with an unheated bed.
Can you get aluminium bolts/screws ? would be interesting to try 3mm aluminium bed with aluminium fastenings and see if it makes any difference.
08-04-2016, 09:05 AM #10
- Feb 2016
- 15
Thnx to all with comments and suggestions fr ejcruz, Aardvark and Geoff
I have been away for several days and will be out all next week (aug7-14) but some updates follow as a kind of summary to your comments and added some detail in one lump:
1-Filament dia is what it is supposed to be.
2-I have changed out the 3M plate cover pad once as it had cracked but I think that was caused by a reading of using acetone and alcohol for a thorough cleaning between prints which removed the protective coating on the pad cover and caused cracks in the 3M plate cover and I did it the hard way by not heating the plate first but removing with a putty knife, cleaning the plate with acetone- What a mess but it was OK at the start until this episode.
3-I am still using 3M masking tape first and then heating to 100 degrees and removing to help the stick & release process. It may be unnecessary but I am reluctant to stop a process that has worked in the past but maybe it is just plain wrong and unnecessary
4-I have cleaned the plate only once recently with alcohol after the 3M pad replacement and felt some un-eveness like small waves as I wiped the surface which makes me wonder if over time I left some residue after the first R&R of the 3M plate cover and it is "growing" over time- It is slight but definitely present but seems evenly distributed.
5-I have not had the "heart:" to replace the pad again but...
6-I put a machinist straight edge on the plate (with cover) moved front and back and corner to corner, used a flashlight to shine under the bottom edge and found only very minor light pattern variations way thinner than anything in my shop to measure same (I not longer have the super thin feeler gauges around but much less gap tham a piece of printer paper)
7-I am willing to replace the plate or to overlay it but do not know where to go for a reliable part(s) that will fit - Any hints in this arena?
8-I am willing to go to glass but read several diff ideas and approaches so do not know the better/best alternatives - Any hints in this area?
Once again, thnx for taking your time to respond to my problem.
