Results 1 to 10 of 110
07-26-2016, 11:57 AM #11
Re: the wet prints, if you're using makerjuice resin, I have some and had the same problem with the finish in my first tests of it. If its oxygen causing problem as Rylan suggested and as it may well be, here's something I'll be trying as soon as it's sunny here again: dissolve vitamin c in tub of water, submerge print in tub of water, place tub of water containing print in direct sun for 30 minutes. Vitamin C dissolved in water should form weak absorbic acid which is a reducing agent to remove any weakly bonded oxygen that may be at the surface layers (a few microns probably). The water also keeps it oxygen free so it can now cure in the sun. If this method doesn't fix it I suspect the problem is something else beside oxygen.
