Results 1 to 10 of 30
07-01-2016, 07:14 PM #1
Jeshua Lacock Presents Lost Shell Sand Casting for PLA 3D Printed Models
Jeshua Lacock is back with a new metal casting technique for 3D models printed in PLA. After receiving feedback that his Lost PLA Casting Technique just 'looked like too much work,' he decided to try another route, and came up with something entirely new called the Lost Shell Sand Casting technique. Also working with PLA, this technique is easier, faster, and more affordable, and the results offer up finely detailed metal parts. The technique also works with ferrous metals. Read more at 3DPrint.com: https://3dprint.com/140523/lost-shell-sand-casting/
07-02-2016, 07:34 AM #2
way cool. dude !
But why is it a different method ?
Looks pretty standard to me.
07-02-2016, 06:10 PM #3
- Jul 2016
- 14
Thank you!
What is different is that with traditional sand casting the pattern is removed from the sand before the metal is poured. Since it has to be removable without damaging the fragile sand mold, it greatly limits the type of geometry possible (undercuts, cores, etc. become a design limitation).
With this technique, the pattern is left in the sand (allowing practically any geometry to be cast) and burnt out directly by the molten metal.
Hopefully I have answered your question, let me know if you have any other questions.
07-03-2016, 11:15 AM #4
okay. Yes now you mention it.
In the lost wax/pla process you heat the mould to melt the wax out before adding the metal.
So why are the tubes (can't remember what you called them) for the metal in and gasses out so large ?
And would this process also work with lead ? or does that not get hot enough to vapourise the pla ?
07-03-2016, 03:47 PM #5
- Oakland, CA
- 935
These guys don't seem to have very high standards for their castings. If one of mine came out that poorly, I wouldn't be celebrating; I'd melt it down and try again. Burning the PLA inside the sand mold evidently disrupted the surface significantly, so any crisp detail was lost. I just hope nobody watches this video and hurts themselves badly trying to do it themselves.
Andrew Werby
Juxtamorph.com
07-03-2016, 04:17 PM #6
- Jul 2016
- 14
That is correct as well.
The the pour tube is called a "Sprue". It is both tapered and oversized to help build up as much hydrostatic pressure as possible (also makes it easier to pour into). It also acts as a "Riser" that stays molten long enough to feed the metal as it shrinks as it cools which is called the "Suck".
Let's see; it looks like lead doesn't boil until 3,180F. So you could get it plenty hot enough to work for the process. How much hotter it needs to be over the melting point of 621F would take some experimenting. I imagine if you got it up to around 1000-1200F that seems like is should be adequate.
07-03-2016, 08:55 PM #7
- Jul 2016
- 14
For staters they are sand castings - which will never quite have the same detail as investment castings. You are incorrect about any crisp detail being lost - many of the original print lines are evident and you can't expect to do any better than that from a 3D print.
Next, these casts are straight out of the sand - no touch up work at all was done to them. It only takes very minor work to sand things into shape.
Finally, where they came out a little rough it was only because the sand wasn't adequately packed tight enough - but a little learning is to be expected with a whole new technique. These are literally the first casts as we learned the new process. We didn't think of it at the time, but all we needed to do is flip the sand mold over and repack the sand from the other end.
And we take safety very seriously! I pour in a full fire proof proximity suit (with full head protection), we pour in a dry sand box, the molten metal is never lifted above waist level, the building is adequately ventilated, we use proper tools, etc. and so on.
07-04-2016, 06:09 AM #8
Have to admit for an uncleaned model it looked pretty good to me.
07-04-2016, 03:53 PM #9
- Oakland, CA
- 935
[Yes, I noticed that. (Nice induction furnace, by the way! Is that home-made?). But I worry about the people who watch You-tube videos and go out to try this at home, in t-shirts and tennis shoes, with the kids all crowding around. You could shake off that "bottle rocket" explosion you got on your first attempt, but it might be a life-changing event for them (and not in a good way).]
07-04-2016, 07:46 PM #10
- Jul 2016
- 14
It is an informational video of what we do here. We go out of our way to discourage others from trying it at home.
How many of these people that you have in mind, just happen to have an induction furnace laying around that is able to melt a pot full of copper at a flip of a switch?
I could only hope that if someone owns *any* type of professional industrial equipment, that they know how to use it properly and safely before attempting to even turn it on.
Note that I spend 5-minutes going over basic metal safety in this video:
Lost PLA 3D Print to Metal Casting; Complete
