Results 1 to 10 of 11
Thread: Help with retraction settings
06-26-2016, 02:13 AM #1
- Jun 2016
- 6
Hi everyone!
I am new to this forum so please let me know if i posted this in the right section.
I have run into a problem with my Duplicator i3 using Simplify3d.
I have read about the retraction settings and tried a few times with different combinations, and I did end up eliminating most of the strings.
The only problem is, that the printer seems to be under-extruding some layers or areas of the print, leaving a weak point.
I have printed a 3dbenchy prior to changing the retraction to have a control.
Another thing is, the printer seems to be leaving gaps between some walls leaving a hole in between the two faces of a print.
Anyone have experienced this issue and managed to fix it?
Thanks!
I can't get the pictures to load up, I will try to post them again.
06-26-2016, 02:24 AM #2
- Burnley, UK
- 1,662
Post your pictures off site and link to them. Use something like Imgur or one fo the other photo sites.
06-26-2016, 02:34 AM #3
- Jun 2016
- 6
Ok, here are some pictures.
http://imgur.com/a/5x6Lz
06-27-2016, 07:09 PM #4
- Aug 2015
- 256
Try printing cooler, if retraction is causing the holes in the print it means it's pulling soft plastic back off the print during the retraction. If you print cooler or add a cooling fan you may be able to prevent this.
Stringing by itself is a sign that you're printing too hot in the first place
06-28-2016, 06:39 AM #5
- Jun 2016
- 6
I tried a few more prints and I may have found the culprit.
It may have been retraction vertical lift as after disabling this setting, the print had almost no stringing at all.
I have reduced the temperature to 190°c and this seems to have helped the print.
There are still small pits in the surface of the print and I also suspect that there is some wobble or minor misalignment between the x and y axis (visible on the windows).
http://imgur.com/a/Z8CeJ
Anyone know if I'm right?
If that is the case, does anyone know how this can be fixed/corrected?
06-28-2016, 10:33 AM #6
- Apr 2016
- 12
The pits look like you;re retracting to much filament. How many mm have you set your extruder to retract at and what speed?
You will always get retraction marks no matter what. Looks like you have your seem position set to Random. Try set it to Aligned or nearest. One or the other tends to chose a corner as the retraction point which makes it less visible and more hidden to a place where people may not look at if its something thats on display.
06-28-2016, 11:10 PM #7
- Jun 2016
- 6
The current settings for retractions are:
Distance: 2.00 mm
Extra Distance: 0.00 mm
Vertical Lift: 0.00 mm
Speed: 30.00 mm/s
The starting position was set to optimize for fastest printing.
Should it be set manually?
If yes, then what would be a good location (x,0 / y,0) or center of build plate?
http://imgur.com/XupDqlg
06-29-2016, 05:25 AM #8
- Apr 2016
- 12
